Rear Wiper not working - fuses ok - Bimmerfest - BMW Forums
Old 05-17-2013, 07:58 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
2004 3.0i with 144,000 miles.
The rear wiper and washer both stopped working recently.
Any thoughts on what may be causing this? Fuses are both ok. (15 and 45 I think)
Old 05-17-2013, 10:09 AM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Do you hear any sounds coming from the wiper when it is 'supposed to be' turned on?
Or is it dead silence?
Old 05-17-2013, 11:01 AM
Mein Auto: 2004 X3 2.5i
There were a couple of other people with the same symptoms and no fuses blown, but unfortunately they never let us know the outcome.
http://www.bimmerfest.com/forums/sho...d.php?t=483628
http://www.bimmerfest.com/forums/sho...d.php?t=682341
The only thing I can think of is the lever switch on the steering column has partially failed even though the front wiper & washer position works O.K.
Old 05-17-2013, 03:10 PM
DanielDavisCO DanielDavisCO is offline
Mein Auto: '97 328i, '04 X3
It could be the motor unit. I just replaced the motor unit in my '04 E83 and it works fine now. I haven't played with the one I pulled out, but I suspect the motor is fine. It's probably the little circuit board that's effed up. Before replacement I suspected the usual suspects. Since neither the wiper nor the washer worked I thought it must be the switch since I should still be able to get fluid out of the washer if the wiper doesn't work. Not the case. Replacing the motor (more likely it's accompanying little board) fixed both issues.
Old 05-17-2013, 04:10 PM
Yes, that sounds very possible. I was thinking that as the washer pump is separate up front there can't be anything electrical at the back to prevent it doing its job.
But as the washers (front and rear) automatically trigger a few wipes, it makes sense that there is a control board at the wiper motor.
It must somehow interface with the washer pump, so if the board fails then neither wiper nor washer work.
And it does make sense that a PCB is more likely to fail than a wiper motor or a switch, maybe from moisture, vibration, extremes of temperature, etc.
Old 05-17-2013, 08:54 PM
mlukas161's Avatar
Re: Rear Wiper not working - fuses ok
Hmmm ok thanks guys for the suggestions. Ill see what I can figure out and will give an update as soon as I solve the problem
Old 05-18-2013, 06:30 PM
mlukas161's Avatar
Where did you buy the motor unit from? I found one for around 180 at Tischer BMW.
Old 06-10-2013, 05:16 PM
I got lucky and found a used one on eBay for about $75 with shipping.
Old 10-21-2013, 12:14 PM
mlukas161's Avatar
Just thought I'd update this thread.
I ended up buying a used rear wiper motor off ebay for around 90 bucks. Just installed it over the weekend and the wiper works again. I suspect something in the circuitry of the old assembly failed. A pretty easy DIY fix.
Only need a 13mm socket, 10mm socket, phillips screwdriver and about an hour.
Old 10-21-2013, 12:19 PM
Mein Auto: 2009 X3
Awesome! Thanks for letting us know!
Old 10-22-2013, 07:39 AM
glad to hear it worked for you I popped the cover off the electronics on the one I pulled out and some of the leads on the board are corroded. I may refloat the solder sometime just for the heck of it and see if that works, but not a priority since I have a working unit in there now.
Old 09-21-2014, 10:00 AM
ironstalin ironstalin is offline
Mein Auto: 1998 323i
how does this thing work?
could someone shed some light on how the rear wiper suppose to work?
i bought my 99 Z3 coupe and the rear wiper doesn't work. when i pull the rear wiper lever i can hear the pump comes on and the washing fluid comes from the rear wiper but the wiper doesn't move at all. i put voltmeter to the motor connector, with the leads off the motor, and checked 12VDC-none. i sliced the same wires that pass through the trunk, eliminating the bending issue at the huntch door. no voltage before the bend either. i removed the glove box and found the control box.
at this point i am suspecting that the position switch in the wiper motor may not be giving a signal to the wiper control box to turn the power to the motor on. any idea if this position switch suppose to be on or off for the wipers to activate? also i would like to find a diagram to check if there is a signal from the wiper switch in the steering, but can't find anything. Does anyone have rear wiper schematics?
thanks for your help
Old 09-22-2014, 11:46 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
You are in the X3 forum.
Try here.
http://www.z3mcoupe.com/forum/showthread.php?t=2682
You want schematics for the E36/8 but they are elusive.
Old 06-14-2016, 12:49 PM
laguna30 laguna30 is offline
Mein Auto: BMWs/Ford trk/British M/C
dead rear wiper
So
I have power
The red w/blue is hot all the time
The brown is not providing a ground to the hot through the circuit board
I have washer - no wiper movement
even trying to ground the motor with the hot on the plug yielded no movement
So an Ebay motor will be installed
Results pending
Old 06-15-2016, 11:10 AM
Frubbel1976 Frubbel1976 is offline
Mein Auto: X3 F25
I had the same problem with mine.
Just open the wiper motor, you wille see a "gearbox", now you have to remove the stick that connects the unit with the wiper, I had to use alot of force, even used a hammer on the side where the wiper was to put it out.
When removed you will see a lot of oxidation on the stick and the housing... clean it up, put some fresh greas on it and it will work again, repat if nessesary.
