Old 05-17-2013, 07:01 AM
birdman15 birdman15 is offline
new to BMW life
Mein Auto: 2008 328xi
gas cap pressure.
scenario:
she fills up the tank, couple days later the yellow check engine light comes on.
she freaks out. Ya my fault!
1st thing I ask is did you put the gas cap back on right. she says yes. I say okay. So I go out check the cap seems that is on. so I take it out and then close it back up. I go and top up the tank last night and again make sure cap is closed tight.
check engine light still on.
so car ( 328xi ) goes in to get scanned this morning. scanner says gas cap. boy does she feel like a dummy. But my question is:
how do you know that the cap is on tight enough so the check engine light does not come on again?
is there a required pressure the cap is SUPPOSED to hold? maybe a seal on the cap is bad?
this is our 1st BMW so I appreciate the help all. won't take me too long to get things figured out. I'm a Jeep guy so used to tinkering with things
cheers
Old 05-17-2013, 07:09 AM
tturedraider's Avatar
Freedom isn't free!!
When the CE light is triggered by the gas cap typically it takes four to six driving cycles to automatically clear. A driving cycle is a "normal" driving trip, not just driving the car around the block. The CE is always triggered by some emissions fault the car registers and doesn't in and of itself require an "emergency" trip to the dealer.
The cap should click once when it has been tightened enough.
www.bmwcca.org
Old 05-17-2013, 07:16 AM
new to BMW life
thanks and yes that is what I thought so. I had a Range Rover and same thing a few driving cycles. it happened on Wednesday night so only yesterday's driving a few miles back and forth to work for her prolly did not reset it.
Scan was free at the dealership
who you kidding EVERYTHING is a emergency when it is not her fault lol!
Old 05-17-2013, 08:18 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
FWIW the new BMW fuel caps are a one turn lock piece, so you can't over-tighten them, they no longer "click". They are generally cheap < $35 via penskeparts.com or elsewhere.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 05-17-2013, 08:24 AM
new to BMW life
exactly my thought. so if it is LOCKED in place and can't be turned anymore there MUST be a seal there. car not with me right now to check.
Old 05-17-2013, 08:30 AM
thekurgan's Avatar
Bad Lieutenant
Yes, the new "seals" are blue that have this instant lock mechanism, the old multi-twist are green. I guess people were over tightening the caps and possibly ruining the seal. It's cheap insurance to get the new unit.
here is a sample:
http://www.ebay.com/itm/BMW-MINI-GEN...item416f9f83d3
Ilse
Bruna
BMWCCA #453648
Old 05-17-2013, 08:44 AM
new to BMW life
perfect thnx for the info! you guys are a GREAT source for info. Nice to see. Exactly the same community feeling like my Jeep chat boards.
cheers have a great weekend all!
Old 05-17-2013, 08:56 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
I really like the green ones though, I like that one-click. So are these new blue ones a twist type of mechanism, where you just tighten it until you can't tighten it anymore, or?
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 05-17-2013, 09:22 AM
thekurgan's Avatar
Bad Lieutenant
Spring loaded it seems, you twist once and it is tight as it will go without over tightening.
Ilse
Bruna
BMWCCA #453648
Old 05-17-2013, 10:05 AM
floydarogers's Avatar
Pedant and Curmudgeon
...is there a required pressure the cap is SUPPOSED to hold? maybe a seal on the cap is bad?...
Yeah, there's a pump in the gas ventilation system that pressurizes the system to check for leaks. Don't know what the pressure is, or what frequency the pressure test is run.
Old 05-17-2013, 10:21 AM
new to BMW life
Kewl will peek at the seal.
Thnx
Old 05-23-2013, 06:03 AM
new to BMW life
CE light came on again, been a week since the cap was described as the issue. Scanner erased the light. must be a bad seal, just ordered a new gas cap with the blue seal. Pick it up today at the dealership. $40.00. fingers crossed this is the issue.
Old 05-24-2013, 05:44 AM
new to BMW life
all seems gtgg so far. new cap installed. I erased the CE light with my scanner. on my scanner it said leak in system then in brackets (very small leak) lol laughed at that one. so far so good.
now all codes cleared.
ran the scanner one more time I got a P0597 code tstat circuit open.
car running at perfect temp. now tstats when they fail should be failing in the open position to stop overheating. So going to ride this one out for a bit seeing that all is working fine. but will keep eye on the temp.
anyone know what the ball park cost is of the tstat? is it tsts & housing together?
cheers
Old 05-24-2013, 05:59 AM
thekurgan's Avatar
Bad Lieutenant
cheers
I'm not sure they are separate, but depending on your mileage, would be a good time to swap out that pump, hoses, etc.
Ilse
Bruna
BMWCCA #453648
Old 05-24-2013, 06:00 AM
new to BMW life
62,000 kms
Old 05-24-2013, 06:49 AM
BiHoTTo115's Avatar
Is there also a way to replace that little green holder on the door to place the cap in, would need to be blue now due to the blue seal. He he.
Old 05-24-2013, 07:34 AM
thekurgan's Avatar
Bad Lieutenant
62,000 kms
preventative, swap the pump is my advice
Ilse
Bruna
BMWCCA #453648
Old 05-24-2013, 07:36 AM
new to BMW life
water pump (i'm guessing you mean) will give that tstat code?
sorry new to the bimmerlife. just want to make sure that is all.
cheers
Old 05-24-2013, 09:28 AM
thekurgan's Avatar
Bad Lieutenant
cheers
I don't know much about the codes from these electric pumps, but I don't see an actual sensor on the thermostat in this photo. These pumps don't seem to last long and are expensive; I was just thinking, if you had a temp related code, preventative will keep you from being stranded somewhere.
Name:	Screen Shot 2013-05-24 at 9.26.53 AM.png
Ilse
Bruna
BMWCCA #453648
Old 05-24-2013, 09:35 AM
new to BMW life
exactly what it said on the scanner was:
P0597 Tstat Heater Circuit Open
no coolant loss and it is NOT over heating
it is going in to the dealership anyways for a bumper to bumper once over. I'm sure they will tell me something be it good or bad lol.
Old 05-24-2013, 09:48 AM
thekurgan's Avatar
Bad Lieutenant
Strange, well let us know what happens, and hope the gas cap was the issue for the pressure issue.
Ilse
Bruna
BMWCCA #453648
Old 05-24-2013, 09:49 AM
new to BMW life
will do! and I'm hoping it was too!!
cheers have a great weekend!
