Old 05-17-2013, 01:09 PM
spanta spanta is offline
Mein Auto: X5
X5 E70 Tailgate light problem
Wonder if anyone can help as I currently have a problem on my tailgate light which I am not sure how to fix. The car that I have is a BMW X5 E70 2009 and have only done 36k miles, but the tailgate light which is housed in the rear not working and I am getting an error message on the dashboard to say the light are 'out'. How do you change it ? The problem is is on the top light which has been marked on the attached picture.
Old 05-17-2013, 03:14 PM
blue dragon blue dragon is online now
Mein Auto: X5 35D
Those are your fog lights, or adaptive brake lights. There panel on the inside of the trunk may have a pop out to get to the lights. If it doesn't, then you need to remove the entire panel. IIRC, there are some screws and regular trim clips
'09 X5 35D - Work horse
'17 X1 MSport - Wife
'17 340i MSport (ordered) - Soon to be daily
Old 05-18-2013, 08:18 AM
Mein Auto: X5
Thanks. Would you know that once I remove the panel and get access to the light panel, can I just change a bulb or do I need to replace the entire panel.
Old 05-18-2013, 06:32 PM
Mein Auto: X5 35D
^^ If its the lines, you will need to change the entire thing. Its a non serviceable LED, If its the adaptive brake light/ fogs, its just a regular bulb that you can change.
Old 04-25-2016, 10:01 AM
m3the01 m3the01 is offline
Mein Auto: '12 X5-35d AW-CI
Got a left brake light malfunction indicator in iDrive...
Are OEM best or sylvania? Just curious what people have found, dealership isnt so close but if there is somewhere someone could suggest online that would work.
Also, is this the inner lights on the hatch or the sides? My wife sent me this pic, i likely will have the answer when i check it out at home.
Thanks for the help~!!!
'12 35D AW-CINN ZAP/ZC3/ZPP/ZTP/456-multicontour/2LE-20's/300-spare/220-self-leveling/4MS/752
www.playabonita.ca -- wifes bathing suit company -- pretty girls...
