E46 M3 (2001-2006)
Old 05-17-2013, 06:14 PM
nkomo nkomo is offline
Mein Auto: 1995 M3
question TC kline set-up guide
So below is the set-up guide from TC kline, and the parts that I'm on top of is the fact that my ride height is already perfect for me and I adjust the rebound and compression shock settings no problem for street, track and inbetween. My question is does anyone who has this, actually adjust the toe and camber when they track, and does it require a mechanic?
TC KLINE RACING, INC. 4163 LYMAN DRIVE HILLIARD, OHIO 43026 PHONE: 614.771.7744 www.tcklineracing.com
RIDE HEIGHT:
FRONT: Set the lower spring perch at the bottom of the threads.
REAR: Relative to the front set the rear (rake) 3/8 to higher .
NOTE: Measure the height from either end of the rocker panel to the ground immediately behind the front tire and in front of the rear tire. CAMBER:
Street Settings Track Settings
FRONT: 1.5 2.0 degrees negative FRONT: 3.0 3.5 degrees negative REAR: 1.5 2.0 degrees negative REAR: 1.5 2.0 degrees negative TOE SETTINGS:
FRONT: 1/16 total toe in FRONT: between 1/16 toe in and 1/8 out REAR: 3/16 total toe in REAR: 3/16 total toe in NOTE: Toe setting will automatically adjust outward as you add negative camber. CASTER:
Set caster bolts as far back toward fire wall as possible. Leave in that position permanently.
SHOCK SETTINGS: REBOUND: * Top Adjuster * Street Settings Track Settings FRONT: turn from full soft FRONT: 1 turn from full firm REAR: turn from full soft REAR: turn from full firm
NOTE: *Warning* - To avoid adjusters sticking, do not leave in full firm or full soft setting!
COMPRESSION: * Bottom Adjuster * Street Settings Track Settings FRONT: 2 clicks from full soft FRONT: 8 clicks from full firm REAR: 2 clicks from full soft REAR: 5 clicks from full firm
