Old 05-18-2013, 05:49 AM
tb30570 tb30570 is offline
Mein Auto: 2008 BMW 335xi Coupe 6spd
335xi Performance Bang for the Buck
I just purchased a 2008 335xi coupe with a 6-speed manual. I'm interested in boosting the power but am not interested in throwing money at mods with little impact....don't tell me to buy a CAI.
I did a little looking around and it looks like the following might be a good start. Am i off path or is this a good place to start?
JB4 PNP (N54 Stage 3) plus BMS USB Cable combo
$509
BMS WW Quick Install Meth Kit w/ JB4 FSB Integration
$479
BMS 135i 335i 3" Performance Downpipes
$379
prices are from burgertuning
Do the BMS downpipes fit an 335xi or just the 335i? If I take the cat out of the down pipe, can i tune out the downstream o2 with the JB4 PNP? I'm not going to buy 50/50 meth/water. Is a meth kit worth it if i only run -30 degree F washer fluid? The info for the JB4 said it will automatically update the air/fuel for e85. Can you run e85 without going to higher flow injectors and fuel pump? how does the JB4 know what % of alcohol is in the fuel?....at wot is the air/fuel set by fixed table, automatically adjust based on a OEM o2 a wide band or are tables adjusted automatically based on air/fuel trim at low throttle?
I don't know anything about BMW's so any other suggestions would be appreciated.
Old 05-18-2013, 06:06 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Hosannas from Heaven, BMS Meth'll getcha to the movie on time, and then some!
Terry's email support is unbelievably good - send him your inquiries - he'll respond.
Knowing WW fluid flow, fuel flow, air flow, air temp and oxygen sensor readouts, guessing fuel content of WW fluid can easily be calc'd. Gotta make an assumption that it's meth.
There are those who claim lean AFR, throttle off on meth for about 2000 rpm. Looking into this myself over at N54TECH - a track issue peripheral to street use, wouldn't affect me, but I like to know. There's a cooling issue, cyl's 5 & 6 too, again a track issue, a problem not ironed out in BMW's design phase, N54.
