Old 05-18-2013, 06:47 AM
limeykraut limeykraut is offline
Mein Auto: 2006 530xiWagon
Voice commands
My new-to-me 530xi has the buttons for voice command, and the bmwvin site shows I have that option, but the buttons don't work. No 'tone' when I press them, and the navigation is silent. Where would I look for a module, and/or is there a master on/off other than what's in the manual? Tia
2006 530xiT, Cold, Premium, Premium Sound, Steptronic, Comfort Seats, PDC, Active cruise, HUD, Nav
Old 05-18-2013, 07:07 AM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
There is no master switch that I know of. But, it may not be your problem. One thing I noticed on mine is the volume knob needs to be adjusted for each individual item. As in phone, music, nav...etc. Like during a phone call. You have to catch it when the person is talking for it to take affect. Not saying this is your problem but worth a shot. Also on the bottom of your IDrive screen when you are using voice commands there should be an icon like a head or something when the computer is speaking. It should help determine if its the speakers, module or IDrive.
Old 05-18-2013, 07:25 AM
Voice commands
I get no response to the voice command buttons, either of them. Does the volume of initializing tone vary as well? The one that tells you it's ready to accept commands? Does the radio volume drop when the Nav is giving instructions?
Old 05-18-2013, 07:26 AM
Voice commands
Oh, and no icon on the bottom of the screen unless I turn off voice command in the Nav and then I get that icon
Old 05-18-2013, 02:36 PM
Yes the volume varies on each seperate thing. You may actually be turning it on when you think off. The icon shows when you start it and the voice says its ready.
Old 05-18-2013, 03:03 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
You should see a voice icon on the bottom of the screen (it looks exactly like the one on the steering wheel) once the voice button is pushed even if you don't hear a beep. Yes, the volume may be turned down, but unlikely for the first use of the voice command.
You may need to get the dealer to update to the latest version, and see whats happening. The voice command works VERY well in my opinion, and does so if you have navigation. It should operate something like this:
Old 05-18-2013, 03:36 PM
Voice commands
Hmmm...ok, I don't get that icon at all. The phone works through Bluetooth, so the connection to speakers is ok I suppose, so maybe it needs an initializing as you suggest??
Old 05-18-2013, 04:37 PM
boramkiv's Avatar
Propellers Up Front
Try the hard reset, remove any discs in both drives, disconnect negative terminal for an hour and then reconnect.
Wait for it to load up, and try again. If not you need to see a dealer or independent mechanic with software.
If your idrive home screen looks like this, you need an update.
If it looks like this, you may not need an update.
Old 05-19-2013, 07:35 AM
Voice commands
Ok, thanks. I'll try that, since my screen looks like your second pic.
Old 05-19-2013, 09:34 AM
Voice commands
Just to confirm, if the VIN decode shows the car has voice command, any necessary modules are there, correct?
Old 05-19-2013, 03:22 PM
boramkiv's Avatar
Propellers Up Front
Yes, but no.
Decoder does show what it rolled out the factory with.
Previous owner could have done something, car could have been rebuilt incorrectly
after minor crash or something.
You never really know.
This is a pretty good VIN decoder, tells quite a lot.
If its still not working, best to get it checked out.
Old 05-19-2013, 03:30 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Here's a complete list of available voice commands:
http://5series.net/info/E60_Voice_Commands.pdf
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 05-19-2013, 03:40 PM
Voice commands
Well, no go on the reset. Nothing changed...hiho, hiho, to the dealer I go...
Old 07-16-2013, 07:35 AM
I finally had time on a Saturday to head to the dealer. He ran the VIN, and said it is equipped properly, so he heads out to the car and when he gets nothing from the steering wheel button, no beep, no icon, no nothing, he says the only option he has is to turn it loose in service with a tech to determine what the issue is...starting at $135.00, and onward and upwards depending in the time it takes to narrow down the problem. He did say his first thought was that it could be the steering wheel switch is bad. Everything else works - bluetooth, the Nav (just silent), it's only the absence of any response to the VC buttons, which makes him think that.
Thoughts? Opinions? I can change the steering wheel column switch, about $70 plus the time. What about the fact that there's an additional switch in the center console? Anyone know a way to determine which switch might be bad?
Old 07-18-2013, 08:12 AM
Anyone? Anyone? Bueller....Bueller...?
Old 07-18-2013, 08:27 AM
boramkiv's Avatar
Propellers Up Front
Does the center console voice button work? That would be a HUGE plus if you have one and it works.
Old 07-18-2013, 08:46 AM
Mein Auto: '06 AW 330xi
Yea I was about to suggest the same. You might have a voice command button by the iDrive knob.
Old 07-18-2013, 09:07 AM
It may be similar to he phone button, all E60s have the phone button, but not all came with Bluetooth. It wasn't standard until 2006 models, before that BT was an option.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 07-18-2013, 01:47 PM
I do have that button by the iDrive (MENU/voice), neither do anything. No beep, no icon, no nothing. It did make me wonder if the button on the steering wheel was the 'master' button, since the SA saw that, but was focused on the steering wheel one.
Old 07-18-2013, 01:49 PM
Agreed, which is why we checked for the correct option being installed, and it is, before he went to the car and tried the button. FWIW, bluetooth works fine, both my iphone5 and the wife's older phone paired without issue. I don't know if the 'voice' that is supposed to be there on navigation, etc uses the same speakers as the bluetooth uses.
Old 07-18-2013, 02:26 PM
Correct, it uses the same mic and speakers for both BT an Voice Command. What was curious to me is that you mentioned that the nav also does not make any sound, correct?
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 07-19-2013, 05:24 AM
Correct. Nav works, and has the option on screen to shut off the voice, but even turned on, there is no 'talking' from the car at all.
So the voice module must be working for the Bluetooth to work? That would lend credence to the possibility of it being the switch, and also it would mean that my other thought of the module being unplugged wouldn't apply?
Old 07-19-2013, 07:14 AM
boramkiv's Avatar
Propellers Up Front
It's not the steering wheel button or idrive voice button or (switches) because highly unlikely that they both would go out at the same time.
I think it's a programming issue especially since you're getting no sound from the nav lady, but getting sound from other audio. The dealer should not have leaned toward the switch because both of them doesnt work and you're not getting Nav instructions, so don't even bother removing the steering wheel.
Old 07-19-2013, 07:20 AM
I asked about software updates, and they didn't think so. Could they have been able to tell from the VIN that it had the latest version? They didn't say that, but... All they offered was to turn it over to a tech to do electrical diagnostics....
Old 07-19-2013, 07:27 AM
boramkiv's Avatar
Propellers Up Front
They can't tell from the VIN, but once you run a test on the modules the versions will show. I just had a member switch from non nav to nav and had to have some items coded because there was NO sound at all. You're good on the part of options listed, but as far as them working it could be a failed module or the way they are programmed to operate.
