Old 05-24-2013, 10:11 PM
ty19345 ty19345 is offline
Mein Auto: 2007 bmw x3 30.si
07 x3 how to turn off electronics after lock the car??
Hi everyone
I just bought a used 2007 x3. I'm new, need some help
I have a Garmin GPS and also a bluetooth speaker setup and iphone connector.
The problem is after I turn off the engine and locked the car, all of my electronics are still on... I've tried probably 10 times and waited as long as 5 minutes each time...
I was looking from outside the window but all electronics won't shut off automatically...
Is something wrong or any setting I should do? I'm afraid it will drain the power if I forgot to turn it off manually.
Thanks for the help!!
Old 05-24-2013, 11:21 PM
Mein Auto: 2004 X3 2.5i
If they are plugged into any of the 3 cigarette lighter sockets they will be on all the time. (Useful for battery charger, trouble lights, etc., but not so good for consumer electronic items.)
German cars typically have it this way, although I think more recent BMW models have one or more of them ignition-switched now. (Another quirk is the radio can be turned on for about 20 mins. without the ignition on.)
You need to do a search on how to easily set up an ignition-switched /separately fused feed.
Those cigarette lighter sockets don't lend themselves well to other uses anyway.
Old 05-24-2013, 11:47 PM
Thanks!!!
No wonders...
My first BMW, so I'm learning everyday.
I think I will just plug in the GPS only when I need to use it...
Old 06-02-2013, 02:27 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
The consumer sockets should turn off after about 30 minutes, this is a codeable option.
Old 06-02-2013, 08:14 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Originally Posted by ty19345 View Post
Thanks!!!
No wonders...
It also could be that its not compatible with BMW electronics.Do a search battery drain . Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 06-02-2013, 08:20 AM
Maybe for later years?
Up to 2007 at least, the list of options doesn't mention this.
("E83 Car and key memory programming options", pdf file under Miscellaneous Documents in the Useful Info. & DIY sticky.)
It makes sense to have the front 2 shut down with the sleep system, if the owner wishes, and keep the cargo area one always live.
