Old 05-20-2013, 01:01 PM
newbmwowner26 newbmwowner26 is offline
Mein Auto: United States
Smile 97' 7 series owners welcome. as well as other
Hey guys new here.....proud owner of a 97' bmw. 740il alpina.....very loud and very fast. Gunna get an oil change for it at mieneke on saturday. Said they were gunna use valvoline....any ideas about what type of oil l should be used???
Old 05-20-2013, 02:59 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
From the owners manual...take note of the bmwusa web address in the bottom right column...if you go to that site, it will give you the current BMW recommendation of approved oil brands/mfgs :
Q {BMW CCA Member #191509}
(SOLD)
Old 05-20-2013, 03:07 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
I only use Castrol Edge or Mobil 1 full synthetic in any of my vehicles. Had a 1994 Chrysler New Yorker that had 227,000 smooth miles on it before I sold it. It has 291,000 miles on it now and buyer still loves it.
Old 05-20-2013, 06:51 PM
Ok....sounds good....what if i used regular oil will.it affect the car in.any way???
Old 05-21-2013, 07:38 AM
No it won't...it is not a 'effective' but regular oils took care of us for years. Just make sure it meets the specs provided in your owners manual or the previous response.
Old 05-21-2013, 08:09 AM
Ok thank you...getting an oil change this weekend gunna use synthetic....one more question thr engine light is on and the previous owner said its cuz of an 02 sensor...he drove it for a year with no problem but forgot to get it fixed. Should i get this this fixed Asap??? Thanks again
Old 05-21-2013, 08:40 AM
QSilver7's Avatar
The CE light (check engine light) comes on when there's an issue with something in the electronic engine emissions system. OBD II was mandated by the federal govt' starting in 1996 for ALL car mfg's to meet to help with air quality. When the CEL illuminates, it means something in the emissions system has registered a fault. It could be an 02 sensor, but it could also be something else that is emissions related.
If you don't have an OBD II scanner, in most states you can take your car to places like Autozone and they will read them for free or allow you to use their scanner. You need to have the code(s) read to know what is wrong or the area that needs attention. Guessing is futile, and you could be totally incorrect if you just throw parts at the problem when you easily have the codes scanned to know which direction to go.
(take note of the 3rd & 4th bullet in 1st image below)
(SOLD)
Old 05-21-2013, 08:53 AM
The car will not pass a smog check with an Autozone, Oriellys and many other auto parts stores will read your codes for free. (If I were to do this, I would probably have them read at at least two places to ensure it is correct before I spent money on parts or repairs). If the O2 sensor is bad, it can adversely affect fuel efficiency and potentially shorten the life of the catalytic converter. If the code is for O2 sensor, I would replace it. The prices for the sensor vary greatly...$85 to $140. I bought my last one at autohausaz.com...and they are usually available at your local autoparts....simple to change, but you need to determine which one. Driving with a bad O2 sensor will not cause any damage in the short to intermediate term.
Old 07-03-2013, 06:34 AM
child seat
Hey guys thanks for the reply...i have a warranty on the car so that will help with the repairs. I have a question i am trying to install a 5 point saftey child seat where are the restraints/anchors on the 97 bmw 7 series...i have an evenflo maestro.
HTML code is Off
