Old 05-20-2013, 04:38 PM
DarkHorseMBA DarkHorseMBA is offline
Mein Auto: 2011, 328i Convertible
Loud cooling fan?
My 2011 e93 has some real loud cooling fans. Today traffic, at a stand still, the fans kicked on and man they were loud.
This also happen when I pull into the garage, stop lights etc. it's about 99f out side and I have the AC on. No warning lights and the oil temp is below 250f.
Is this normal, should I be concerned?
Old 05-20-2013, 04:54 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Sounds about right, these cars generate a lot of heat - if it is really excessive, it is an indication the water pump is going to fail, but in 100 degree heat in traffic, it is normal and they do move a lot of air!!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 05-20-2013, 06:52 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Hey Darkhorse, my fans on my '09 328i really are loud as well.
Old 05-20-2013, 08:05 PM
Loud cooling fan?
Thanks, feeling better about it. Had the car checked out at the dealer after I bought it in march. The SA said it was in great shape, and still has factory warrantee until September 2014.
As for the water pump is there a way to check that, or it'll just fail when it wants to?
Old 05-20-2013, 08:22 PM
Danforth Danforth is offline
Mein Auto: 2009 335i Xdrive
I have an 09' 335i Xdrive coupe and the fan is super loud, I hate it people always comment.
Does anyone know what you can upgrade to aftermarket parts to eliminate this?
Old 05-21-2013, 05:52 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Your water pump is dying....
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 05-21-2013, 06:17 AM
DSXMachina's Avatar
Bimmerdex 7.4!
The BMW fans are as quiet as they can be given the volume of air they are moving. Don't even think about changing them. Think of them as the cooling system equivalent of a performance exhaust system and you will come to love the sound.
Next time one of your friends comments about the noise just tell him that your fan blades came off a Messerschmitt. And theirs came off a Hampton Bay ceiling fan.
Old 05-21-2013, 06:19 AM
DSXMachina's Avatar
Bimmerdex 7.4!
We are all dying, some of us more slowly than others. "When?" is what we don't know.
Old 05-21-2013, 06:27 AM
Loud cooling fan?
So any way to avoid sudden death?
Of the water pump that is.
Old 05-21-2013, 08:01 AM
tturedraider's Avatar
Freedom isn't free!!
I'm not quite sure what is going on, but contrary to some previous opinions you were given, this behavior is not normal. My car has exhibited it four or five times in the past six months. Most times I have pulled into a parking lot and turned off the car for two or three minutes and it has corrected itself. A couple of times it has corrected itself before I stopped the car. I am unsure what is causing it, but I suppose it could be a sign of a failing water pump. My car has about 86k miles on it.
What I'm referring to is a loud roar from the fan that can be heard with the windows up and the radio on. It is not a normal condition.
www.bmwcca.org
Old 05-21-2013, 09:43 AM
That sounds like a water pump starting to go - the OP said it happened in high heat in traffic which is not abnormal, but yours definitely sounds like a potential water pump issue and the fan is starting to compensate and your mileage is about right for water pump life.
Unfortunately with electric water pumps you don't get much warning if any, they just up and die one day, some people get some warning signs, others none.
It seems what the water pump flow rate drops off a bit and then the cooling fan runs faster to compensate, then the pump just up and dies one day.
It may be worth checking for codes to see if the car has seen anything with the water pump, but otherwise you can either wait until it dies or proactively replace it (which is not cheap!).
Old 05-21-2013, 11:26 AM
DSXMachina's Avatar
Bimmerdex 7.4!
There is a way to manually activate the water pump in a stopped engine (with the key on). It is part of the bleeding procedure. Unfortunately it is known to the smart techs who work for me and not me, and I'm not at the shop today.
If the OP activates just the pump he'll know for sure if that's the noise. Anyone?
Old 05-21-2013, 11:39 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Old 05-21-2013, 11:46 AM
Might be the same as 335, steps 43 ~ here
Old 05-21-2013, 12:01 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Good catch, that procedure does sound familiar. OP, run your pump and if it the noise sounds like the pump then it's the pump. If not...it's normal high speed fan sound. Probably. Maybe.
Old 05-21-2013, 12:09 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Failure will either be of seals, or electrical. There's nothing you can do preventively if it's electrical, other than changing your electricity filter* every 30,000 miles. The best way to keep your seals fresh is to change your (lifetime!) coolant every 2 or 3 years. This is because they all pick up microsolids which remain in suspension and are abrasive to the seal lip.
Old 05-21-2013, 02:15 PM
I've taken it to the dealer and mentioned the fans, about a month ago. They kind of brushed me off as if I was making a big deal of nothing. That being said they did "check for codes" and fond nothing wrong with the car in general, not looking for the pump or fan issue. I assume no codes is a good thing. If the pump is dying I don't think it's letting on, outside of the fan noise.
Old 06-15-2014, 07:03 AM
Len1975 Len1975 is offline
Mein Auto: 2005 X3 3.0
Did you ever find out what the problem was, because I had this same issue. I took my car to BMW and no they found no codes and brushed me off and said all was fine...I cannot take this loud embarrassing noise.
Old 06-15-2014, 07:21 AM
Got the same response from my dealer. Just been living with it.
Old 06-15-2014, 09:10 AM
GeForce GeForce is offline
Mein Auto: 328xi 2008
I own an 08 E90 and when I kick on the AC it is pretty loud. Turn off the AC it's quite like a stealth kitten hunting after a mouse!
Luckily I do not have to turn on my AC much in my neck of the woods.
Old 06-15-2014, 09:16 AM
In fall - spring I might be able to get away with that.
Texas summer, no way! I even run the AC with the top down :-). The wind deflector help with this.
Old 06-15-2014, 09:33 AM
sna66 sna66 is offline
Mein Auto: 328i e93
I recently got an 07 328i and I'm in Florida heat. The first time I heard the fan kick in I really thought there was a problem but after reading similar experiences I'm not concerned
Old 06-15-2014, 11:46 AM
z28forlife z28forlife is offline
Mein Auto: 2000 e39 540i
I work for bmw as a technician. Your water pump or thermostat or both are on there way out. One day you'll get a check engine light and then the dealer will be able to replace it under warrenty. But until a check engine light is on they're hands are kinda tied. Warranty is a bitch to deal with. But not to worry, even when it does go out it will keep the thermostat open so the car won't overheat. The thermostat and water pump are both electric so one day they work and the next they don't.
Old 06-15-2014, 03:10 PM
Mein Auto: '06 AW 330xi
If the radiator fan is kicking on right after a cold start or is screaming right after driving, your water pump is most likely going.
Old 06-15-2014, 05:39 PM
I hate that noise...It never did it before and now it just will not stop and it is really loud!
