Old 05-21-2013, 08:32 AM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
335i- looking
Hey guys, I'm a frequent member on the e39 boards ('97 528i) and I have finally convinced my mom to trade in her 05 Maxima for a BMW, more specifically a 2008 335i sedan. My question is, are these cars DIYable, to an extent? (I know this chassis is much more technologically advanced than my e39) I do all the work on my e39 with my father as he is a mechanic and was wondering if we could do a majority of the work/maintenance on the 335i if need be.
PS: the 335i has 54k miles and is a CPO with 2 years or up to 100k miles left on the warranty I believe
Thanks for the advice!
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 05-21-2013, 08:56 AM
lqaddict's Avatar
lqaddict lqaddict is online now
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
Most of the maintenance can be done by DIY.
I'd suggest these boards for more in depths DIY guides.
BMW CCA Member 454031
Save the manuals
Old 05-21-2013, 09:55 AM
floydarogers's Avatar
Pedant and Curmudgeon
Most common maintenance tasks are easy DIY. You might consider getting an OBD II code reader (that can read BMW specific codes) if you want to go a bit further. Even changing batteries you need a reader/reset.
Old 05-21-2013, 10:33 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
Convince your mama to get a 328. The 335 is great when it's under warranty. Not so great when it breaks out of warranty. The 335 has a lot of problems which will require major expensive repairs before 100k miles. They will almost certainly include:
A/T mechatronic sleeve replacement (you need to drop the pan to replace the sleeve and then go through BMW's ridiculous A/T fluid filling procedure from under the car with the engine running)
Oil filter housing gasket replacement
Decarbonizing the intake ports and valves (requires removing the intake manifold and is a recurring maintenance item)
electric water pump and thermostat
This is all DIY stuff for anyone with a Bentley manual and the time to spend a few weekends worth of work.
BMW extended the warranty on the turbo waste gates for a rattle up to 8 years and I think 82k miles. But whether you can get new ones or not, turbos (there are 2 on the 2008) are a wear item. They will need to be replaced if you keep the car long enough.
Old 05-21-2013, 11:17 AM
lqaddict's Avatar
Salz und Pfeffer
Out of the issues you listed, only "Decarbonizing the intake ports and valves" is unique to 335.
The other issues have the same likelihood to happen to a 328 as it does to 335.
Save the manuals
