Old 05-21-2013, 08:41 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
Koni Yellow shocks 2006 E90 330xi triggers DSC
Recently I had Koni Yellow shocks (should be on default softest setting) installed at 4 corners (using original OEM struts, OEM springs), had 4 wheel alignment, using DWS tires.
I noticed that when I corner relatively fast, DSC comes on and slows certain wheels.
This never happened before with the OEM shocks. So far it only happens at the same area of road (in dry weather, no sand).
Any ideas?
Old 05-22-2013, 07:24 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Could be a shock/spring mis-match. Most who stick with the OEM springs use the FSD variants.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 05-22-2013, 07:28 AM
This morning I am noticing a grinding noise coming from the rear when I brake.
This particular issue is fixed after rotor/pad replacement.
Still have to re-test DSC issue.
