Old 05-23-2013, 07:15 AM
vk535i vk535i is offline
Mein Auto: 535i
Is my gas tank reading correct?
Hello all,
Since I own this car, I've never paid attention on the gas tank capacity. Just few days ago, the gas tank run down low ( 32mile) so I stopped by gas station and filled up. The gas pump stop at 11.5gal. I try to fill more in but the top-off protection at the pump keep pop-off. I finally got about 11.8gal in the tank. Starts engine, the gas guage showing full tank as it support to. So curious, I got home check out the gas tank capacity in the manual, it should be 18.5 gal (including 2.1 gal reserved). Why I filled only 11.8gal and it already full? is the guage reading correctly ?
2014 550i, Jet Black / Black Dakota Black, Bamboo Anthracite Wood Trim, M-Sport Package, Executive Package, LED Lighting Package, M Aerodynamics Package, HUD, Adaptive LED Headlight, Harman/kardon Surround Sound System. Surround/top View Camera, BMW Apps via SmartPhone, Split fold-down-rear seat ...
Old 05-23-2013, 07:47 AM
whoever whoever is offline
Mein Auto: honda civic
Did you drive a lot on local? I just recently noticed my mileage remaining dropped 10 every time I start the car and then drop by 1 for every block or every minute I drive. Then it's climb up 10-20 on highway.
Old 05-23-2013, 08:01 AM
Mein Auto: 535i
I think you mis-understand my question. it's Not the mileage drops to 10 but the tank capacity kindda smaller than in the manual says . For E60, it should be 18.5gallons, but on my car I fill around 11.5gallons already full tank even I let the tank empty down to 30miles remain. So I don't know if the gas tank on my car is smaller or something else ...
Old 05-23-2013, 10:37 AM
I understand you perfectly.
I notice that miles to gas up drop like rock when I start and drive locally. More like drop 10 to start and then drop 1 for every 1/4 miles of local driving. So, if you drive a lot short local trips, the 32 remaining shown on computer could be way off. But I don't drive enough short local trips to prove if that's the case, or if the discrepancy accumulates with more local drive.
Old 05-23-2013, 10:44 AM
Mein Auto: 535i
I drive local lot more than highway. So it's seem like the gas gauge give out the fault info telling that only some miles left before tank empty but reality is maybe more than 5-6 gallons are remain in the gas tank.
this is odd !!!
Old 05-23-2013, 01:40 PM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
this is odd !!!
What did your gas gauge say when you only put 11.5 gallons in the car? I've noticed the same thing that the other people responding to this thread have said, that when you are driving around town, particularly if you are driving aggressively, your instantaneous mileage will be very low (<10 mpg), so your remaining range will drop as well. I've seen my remaining range go up from 30 or 40 miles to 70 or 80 miles if I go back on the freeway and drive at a reasonable speed (i.e., my instantaneous mileage goes up to 27 mpg or so).
Think of it this way. If you're only getting 7 mpg, then 7 gallons of gas (18.5 minus 11.5) will only take you 49 miles. BMW (and all other cars) have a fudge factor built in so that you don't immediately run out of gas when you have 0 miles remaining. Figure 2 gallons. So, now you only have 5 gallons of gas to use. 5 time 7 is 35 miles remaining.
Keith
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 05-23-2013, 02:03 PM
Mein Auto: 535i
Keith
When the digital gauge shows 30 miles to the empty, I look at the analog gauge and the needle point at around 1/8 of the tank.
After filled up 11.8 gallons, my gas analog gauge needle pointed at FULL tank with remaining 420 miles on digital gauge. So it's seem the computer calculation kindda off if driving local with gas pedal on/off too much.
Old 05-23-2013, 02:19 PM
johnniek johnniek is offline
Mein Auto: 2009 528ix sedan
Forget the miles to empty. His question is why the needle reads near empty but only took 11.8 gallons to complete full. It has to be a gauge issue. Local or highway is irrelovant.
Old 05-23-2013, 02:44 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- met in Rome, named Mo
Mein Auto: 2008 535i
Put in two tank fulls of Techron. You might have a sulfur build up.
FWIW, with about an eighth left on the needle, you should need more than 11 gals. I just filled up with a quarter tank on the needle, and it took a bit over 11 gals.
http://www.techron.com/techron-concentrate-plus/
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 05-23-2013, 02:47 PM
+1 on techron. Really helps fuel gauges.
Old 05-23-2013, 03:06 PM
Mein Auto: 535i
Technically I put in 11.8 gallon on 1/8 of needle and I use Chevron gas and Texaco gas has Techron on it.
So the gauge reading maybe correct only the mile left is calculate wrong.
Old 05-23-2013, 04:37 PM
Campfamily's Avatar
Help me out here.....how will Techron help out a fuel gauge?
I agree that if the fuel gauge reads 1/8, and you're only putting 11.5 gallons in, something ain't right. I put close to 15 in with the gauge at 1/8.
Old 05-23-2013, 06:20 PM
Kamdog's Avatar
As I understand it, sulfur can accumulate on the sending units, and Techron cleans that off.
Old 05-23-2013, 06:30 PM
pjinca pjinca is offline
USAF Pararescue Veteran
LMAO, not quite. The analog gas gauge does NOT include the reserve 2.1 gals in it's calculation. This means at 1/8 it is not measuring the full 18.5 gals, it is measuring 16.4 gal. Also, the "digital" gauge measures based on "instant" mpg vs it's overall cumulative mpg reading. So you may very well have just needed 11.5 gals. The gauge is not there to allow you to run the tank dry, there's a reason why sometimes after a long highway drive my light will come on at 60 miles to empty. However, if I drive all local for a few days, it will come on at about 40 miles to empty. It happens. Also, NEVER let it get below 30 miles to empty, even your owners manual says that could lead to failure of the fuel pump.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 05-23-2013, 08:07 PM
racooper3 racooper3 is offline
BMW Master Wannabe
Mein Auto: 2005 BMW 545i
LMAO too. Fubar post.
Old 05-23-2013, 08:30 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Originally Posted by pjinca View Post
lmao, not quite. The analog gas gauge does not include the reserve 2.1 gals in it's calculation. This means at 1/8 it is not measuring the full 18.5 gals, it is measuring 16.4 gal. Also, the "digital" gauge measures based on "instant" mpg vs it's overall cumulative mpg reading. So you may very well have just needed 11.5 gals. The gauge is not there to allow you to run the tank dry, there's a reason why sometimes after a long highway drive my light will come on at 60 miles to empty. However, if i drive all local for a few days, it will come on at about 40 miles to empty. It happens. Also, never let it get below 30 miles to empty, even your owners manual says that could lead to failure of the fuel pump.
+100
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 05-24-2013, 07:17 AM
Mein Auto: 535i
so technically my analog gauge measuring correct the amount of gas on the tank then. cuz when the needle point at 1/8 of the tank, I can put in 15.8 gal (this top off). I normally re_fill gas around 1/4 of the tank or more but lately last few times I let the gas went down almost empty then fill up and look at the receipts, once showed 11.5gal and another one showed 11.8 galon. Will try again few times
Old 05-24-2013, 07:28 AM
The only thing you can prove by keep trying that is the toughness of your fuel pump
Old 05-24-2013, 07:44 AM
Mein Auto: 535i
I just let the gas down to 1/8 of the tank. I don't think it may effect the fuel pump (and hope not)
Old 05-24-2013, 08:08 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
In my opinion I think the gauge is reading incorrectly.
When the gas tank on my car gets empty like 20-15 I fill almost 18 gallons all the way to the cap (takes about 5 minutes)
last week I filled the tank with 100 octane it was 10$ a gallon
http://tinypic.com/r/23prax/5
Old 05-24-2013, 05:31 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
$180 for one tank of gas? wow. How many miles will you get out of that tank of super-gas?
Old 05-24-2013, 07:32 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Why?
Old 05-24-2013, 07:34 PM
Mein Auto: 535i
cuz he is rich LOL
Old 05-24-2013, 08:56 PM
booyaazaa's Avatar
Originally Posted by schpenxel View Post
Why?
I was going to ask that too. I don't even run 100 oct with my mix, at most it is 95 oct for my 18 PSI map. Granted that V8 will not have a single knock or ping when going WOT.
2009 AW 535i
Old 05-25-2013, 06:59 AM
GOR777's Avatar
It was about $150, some 91 was in the tank when I filled up, really didn't looked at the miles but the gauge was reading 497. I am sure I didn't drive that much tho
