Old 05-23-2013, 06:24 AM
vinnieg vinnieg is offline
Mein Auto: 2002 Tundra
2008 - 2010 Turbo Lag
Hello all,
I'm looking to buy a 2088-1020 335i Convertible. I've driven a couple of 2008's and a few 2010's. I've noticed the 2008's seem to have more turbo lag than the 2010's. Is this correct? Or did I happen to drive a couple of cars with issues? If correct do the 2009's have the same issue? There also seem to be fewer 2009's for sale.
Old 05-23-2013, 06:27 AM
2008-2010. Couldn't edit post.
Old 05-23-2013, 06:38 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
Were the cars you drove MT or AT. If they were AT was it in sport mode? There are fewer 09s because fewer were sold, right in the heart of the recession. 08 and 09 definitely have the N54 motor, I can't remember if the N55 came in 10 or 11. I like the N54 better, but some do not. As far as turbo lag some on the 'fest complain of it. There have been so many software updates, some are done on a given car and not on another. All I know is in my MT N54 running E0 gas, as long as I am in the proper gear for the rpms, I have no turbo lag at all. It pulls just like the small block V8's I have driven in the past. So all I can tell you is that it is possible to find one with no turbo lag, but it may require a certain set of circumstances
N4S
Old 05-23-2013, 06:50 AM
They were all AT. Not sure about the sport mode. Would that make a difference in the turbo lag?
The 2008's seemed to have a little lag, the 2010's however felt like someone was pushing me when I took off!
Old 05-23-2013, 09:31 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
BMW released a software update for the 2008 N54 which addressed the turbo lag issue. But the DME was reflashed on a customer complaint basis, not under a recall. If the previous owner didn't complain, the software probably wasn't updated. The 2010 has the N55 motor, which uses a single turbo with twin scrolls and the N54 uses two turbos. So they probably perform differently.
Old 05-23-2013, 11:54 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by vinnieg View Post
Hello all,
Try this: Place your foot totally flat on the accelerator.
I kid you not.
Old 05-25-2013, 06:58 PM
SLV335I SLV335I is offline
Mein Auto: 2007 6 Speed 335I Sedan
I'm almost positive that the N55 single turbo started in the 2011 3 series models.
Old 05-25-2013, 11:21 PM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
2007 - 2010 335i models and all 335is models have the N54 engine, and 2011 - current have the N55.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 05-26-2013, 06:12 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
+1, my 2008 was lag free until they updated the software, they introduced the lag to fix other issues like noise from the wastegates, then slowly released software updates to fix the lag, my last update about 2 years ago got rid of the lag again and then a GIAC software flash and the Alpina transmission flash made everything perfect!
If you end up finding one you would like, I would recommend you ask the dealer to update all the software as part of the deal and request a final test drive before you sign on the dotted line!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 05-26-2013, 06:22 AM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
I kid you not.
twins help vs. single in this respect the single ones I've been in I notice it way more than I did in the almost 40k I stuck on my 335i.
Old 05-26-2013, 07:36 AM
Brings up a point: What is the point of an adaptive transmission?
If you liked it when you test drove, so what? It changes.
If you didn't like it when you test drove, so what? Again.
This is the question: If you can't see the adaptation of the transmission, is it what you like, or will it be, or won't it?
Who is this Erwin guy?
