2004 E60 530D Remote Control Do not stop engine - Bimmerfest - BMW Forums
Old 05-23-2013, 02:58 PM
Dunhinho Dunhinho is offline
Mein Auto: E60 530D SE
If you guys can help with this one I'd appreciate it.
I've got an 04 530D with 91k on the clock that has this intermittent fault. The strange thing is that the car will start as normal most of the time, but when there are temperature extremes, such as when the car has been parked in direct sunlight, the main key will not operate. Once the key is in the ignition & turned no lights come on.
I can use the valet key to operate the car as normal, but want to remedy the problem before something else happens and I get stranded.
The other odd thing is that the "Remote Control" message comes on when I turn right, like round a roundabout.
If anyone has had a similar problem or can suggest what the solution would be it would be a great help.
Cheers
Old 05-23-2013, 04:31 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I am guessing that you have an LCI car, since you mention the "Valet key". If so you have the square key, you can change the battery in the key, your owner's manual will tell you how. If you have the older style "diamond" shaped key you will need to replace the key, those keys do not allow a battery change and are charged while driving.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 05-25-2013, 04:18 AM
Thanks for the help. I initially thought it would be a key change due to battery failure but my local Main Dealer didn't think that this was the problem as the remote lock / unlock was functioning as normal. It's worth a try I suppose.
Old 12-18-2015, 07:41 PM
travisn travisn is offline
Mein Auto: 04 530
bump. I started getting this error. Seems like it might be #8 or maaaaaybe #12 http://www.realoem.com/bmw/enUS/show...diagId=32_1435
Any resolve to this issue yet?
Old 12-24-2015, 09:11 AM
Mein Auto: 04 530
Dang, no one?
Old 01-26-2016, 04:22 PM
Mein Auto: 04 530
Bump, car is stuck at work now.
Old 02-01-2016, 03:45 PM
Mein Auto: 04 530
So I found that if I use the valet key it starts every time, even when the regular key does not before and after the valet key start. I guess that means the key is dying? But the unlock button works every time.
e60 5-series, ignition, key fault not working 3, remote key
