Old 05-27-2013, 07:35 AM
paultyk paultyk is offline
Mein Auto: 2012 650I Coupe
AC Compressor Magnetic Clutch
Did anyone changed ac compressor clutch? I found clutch assembly on ebay. Dealer sells only compressor with it, not seperate.
Old 06-13-2013, 08:09 PM
jallan3 jallan3 is offline
Mein Auto: X5 3.0si E70
Im going through this myself..
The Clutch bearing disintegrated and ate itself. The AC worked fine until the clutch mechanically failed, so my compressor is good but clutch is bad.
I looked online and sadly found that I have to buy the whole compressor... Cant just buy the clutch.
I started searching around for AC Compressor repair services but couldn't find much at all.
Curious - where did you find just the clutch?
Old 06-28-2013, 12:22 PM
carrazco650i carrazco650i is offline
BMW Rookie
Mein Auto: 650i
I had the similar experience on a different car. I cross matched the bearing and replaced it and Wala!. I wonder if you can press a new one on these if the clutch is still intact but if the bearing is blown/ bad.
2010 BMW 650i, Lowered Eibach, 255/45R19 Front, 285/35R19 Rear. Resonator & H box delete, and X pipe installed upstream.
Old 06-28-2013, 06:33 PM
HerbP HerbP is offline
If you have to recharge the system, Sam's Club has a 30lb can for 80.00! This might not be country wide, but it is one heck of a deal!
Good Luck!
