Old 06-10-2013, 03:17 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by Salmantheman View Post
Tried to figure out how to pull out the C-pillar today.. but it wasnt a few plastic clip removing job. Ill research a little on bimmerfest and check that tomorrow morning
pop the airbag tab off & there is a screw that you need to remove .
Old 06-11-2013, 02:16 PM
Salmantheman Salmantheman is offline
Ms. AWesome ;)
Mein Auto: E66
Thanks for that Paper... I unclipped the airbag sign and saw a (weird) screw i need to go and buy a driver to open that in the morning. Will that first thing in the morning . Cheers
Old 06-11-2013, 03:12 PM
dannyb1027 dannyb1027 is offline
Mein Auto: White 2002 745I
This is like an interesting book and I can't wait to see how it ends.
Old 06-11-2013, 09:23 PM
PAPER's Avatar
CRISP & CLEAN
I think it is a T 25 , but not positive .
Old 06-12-2013, 01:25 AM
Ms. AWesome ;)
Mein Auto: E66
ITS WORKING BACK AGAIN.
Ok so heres what happened. (btw it was a T20) So i finally opened up the c-pillar and found the FM module. As i unclipped the Fiber clip i saw that the red light was working. I thought of taking a picture and then to send it to you. But before i did that i would tried looping the FM module and it was working. I saw all my options on the MMI except the FM and AM option.
Thanks PAPER you are a champion. You have a fan for life
PS. I will replace the FM module over the weekend and will change the MMI and ASK unit to a facelift version. cheers
ID:	381402   Click image for larger version
Old 06-12-2013, 02:34 AM
BSOD BSOD is offline
Mein Auto: 2006 BMW 650i Sport
Result !
2006 650i Sport
Old 06-12-2013, 05:34 PM
PAPER's Avatar
CRISP & CLEAN
GLAD to hear ..
if you do change to the FACELIFT ASK unit then get the FACELIFT AT AM & FM Tuner also .
You will need it so everything works .
Old 06-21-2013, 08:54 PM
fsomuah fsomuah is offline
Mein Auto: bmw 745li
Nothing on my Idrive Works
I have the same problem on my 2004 bmw 745Li.....what exactly should I change to get it fixed......
I've been reading this nice tutorial for days and am still wondering what exactly should I replaced.....please advise ....
I learn the other guy was saying he's going to change his AM and FM module....should I do the same on mine from the C Pillar???
Old 06-21-2013, 09:20 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
There are 6 to 10 devices on the MOST bus (fibre loop). You need to track down which one is faulty before you start replacing stuff.
Old 06-21-2013, 09:34 PM
PAPER's Avatar
CRISP & CLEAN
Re: Nothing on my Idrive Works
X2
Old 06-21-2013, 09:52 PM
Please do I need to follow the same steps you guide the other person or I should just open the C Pillar and change the AM and FM module to see what will happen.
Am saying this because my situation and his are exact the same ......it's only the climate on the idrive works.....no radio,cd,wa,communication,GPS .....pls help me
Old 06-21-2013, 10:48 PM
SuperSnoop's Avatar
Yes, you need to follow the same procedure to determine the faulty module. The symptom will be the same for all MOST devices.
Old 06-22-2013, 03:24 AM
So I had to look for a red light or red blinking light.....is it the light sign of faulty ???
Old 06-22-2013, 06:12 AM
I just checked the lollipop in the glove box and L7 and both red light is blinking .....I don't want to go further just waiting for ur next advice
Old 06-27-2013, 01:10 PM
Ms. AWesome ;)
Mein Auto: E66
fsomuah... i am not sure how far you need to go to solve your problem.. but honestly i would go to any length... if all the modules are intact and i believe its just your MMI ...
An update. I updated my fm modules, the ask unit and MMI to a facelift version. the screen looks AWEEESOME ... i used DASHSOFT (with the help of my USD to OBD2 (inpa kcan cable) ) and i also added an AUX cable and tucked it in the side compartment. PAPER you are a champion and thanks a zillion.
Old 06-27-2013, 01:25 PM
PAPER said my MMI unit is ok that I should change my Ask Unit which I did ....I also bought fm and Am module but don't know how to install it .....
I got a stage where I have to fold one backseat but I don't knw how...
Any help pls
Old 06-27-2013, 01:59 PM
PAPER's Avatar
CRISP & CLEAN
Any help pls
I said it could be your Ask unit or any
Unit on the fibre optic line
Old 06-27-2013, 02:36 PM
Ms. AWesome ;)
Mein Auto: E66
If i can change the FM module any on can... As paper mentioned in this thread... pull out the the AIRBAG sign and unscrew the Screw that you see, everything else just clips out... and you will see the module right in front of you.
fsomuah. its diagnosis stage here. so as PAPER said it COULD be any unit on the fiber optic line....
Old 06-27-2013, 02:39 PM
PAPER's Avatar
CRISP & CLEAN
He needs a lollipop before he can start
Checking modules .
Old 06-27-2013, 02:47 PM
PAPER's Avatar
CRISP & CLEAN
That's great , Glad your all set up & running smooth
with the FaceLift parts in your car
Old 06-27-2013, 03:19 PM
I can't wait for my to start working again.... No clock, radio, cd, weather and alerts I have only the climate working.
Old 06-27-2013, 03:22 PM
Out curiosity I did open the c pillar and the fiber optic line is blinking(red light) that's that mean anything great ?????
Old 06-27-2013, 05:55 PM
PAPER's Avatar
CRISP & CLEAN
you stated in your PM =
Hi Paper I just finished checking my ASK unit and the red light is blinking BUT the MMI red light is NOT blinking......
Please what's the next step
this points to your Ask unit .
Old 06-28-2013, 05:25 PM
Ms. AWesome ;)
Mein Auto: E66
also the cdc ....
Old 07-04-2013, 11:03 AM
Very soon am going to receive my already ordered ASK UNIT and my sound system will start working again....I really can't wait
