E36 (1991 - 1999)
Old 05-29-2013, 08:26 AM
tyresebimmer tyresebimmer is offline
Mein Auto: 95 325i
ignition
esmy car wont start. as i turned it over its stuck to were the instrument panel is on but id locked up and the key can be removed while the panel is on and i cant turn it off.
Old 05-29-2013, 08:37 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
I have no idea what you are saying. Please try to be more specific in explaining what is going with your car. My thoughts now range from you have the wheel locked to dead batteries to anything else. More info is needed.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 05-29-2013, 08:40 AM
Mein Auto: 95 325i
the ignition is locked and wont completely turn over.its stuck on the first turn that turns the instrument panel on.
Old 05-29-2013, 08:43 AM
Much better. Can you turn the steering wheel?
Old 05-29-2013, 08:44 AM
Mein Auto: 95 325i
yea but it wont continue to start nor can i turn the car off. i just unplugged the battery so it wont die.
Old 05-29-2013, 08:56 AM
Sounds like your tumbler is toast.
Old 05-29-2013, 08:57 AM
Mein Auto: 95 325i
tumbler?
Old 05-29-2013, 09:58 AM
Your ignition tumbler. The thing you put your key in.
Old 05-29-2013, 10:10 AM
mandla mandla is offline
Mein Auto: BMW 323I
Hello community it is a pleasure to become a member of this wonderful Group and i'm looking forward to learn new things, Thanks
Old 05-29-2013, 10:26 AM
Mein Auto: BMW 323I
Hi Guys i seem to have a problem starting my BMW 323i 2006 model, my brother played a radio until the battery went flat so my naubhour jump started a car using jumper cables yesterday and the car started but this morning when i tried to start a car again it wouldn't start therefore i used the jumber cables to start a car just like what my naubhour did but the car wouldn't start, the screen on the dash board read as follows, electrical steering wheel faulter the car would not start contact Bmw, please give me some advice.
Thank you
Mandla
Old 05-29-2013, 12:27 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Thank you
Mandla
You are my favorite. You might need to replace the battery. At the very least try to diagnose your alternator.
OP: Either your tumbler is bad or you need to wiggle the steering wheel.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-30-2013, 04:10 AM
Jeffjhd Jeffjhd is offline
Mein Auto: 1995 M3
ignition
Hey guys I just spent 400 on some tires and went to go start up my baby and... The key spins 360 forward(happens sometimes, but not all the time), so I spin it backwards around to lock it back in the off position. Then went to go start it again, this time the key didn't budge! Steering wheel is NOT locked, and it seems my radio/ instrument cluster remained on. And I couldn't get the key to spin at all. I could remove the key and insert it, just couldn't spin it. My steering wheel wasn't locked either . Anyone know what could be the issue? I just bought new tires and now this BS is happening!
Old 05-30-2013, 05:47 AM
Okay, if your key won't spin and your steering wheel is not locked, there is a 95% chance that you key tumbler is bad. It happens, it is not uncommon. For everyone, I have uploaded the realoem.com diagram of the steering column. It is part number 5 in the diagram. If you click here:
http://www.realoem.com/bmw/showparts...09&hg=32&fg=30
You will get the full parts list as well, including the part number needed to order a replacement.
Old 05-30-2013, 05:49 AM
Mein Auto: 1995 M3
ignition
Thanks ill check it out
Old 05-30-2013, 03:51 PM
Mein Auto: 1995 M3
ignition
Ok, I looked up the part on bav-auto, and it comes with a key as well. Am I going to have to replace the door lock also? Is this even the right part number for a 1995 m3? : # 32 32 1 156 757
Old 05-30-2013, 03:58 PM
petriej's Avatar
Most folks who don't want 2 different keys take the pins out of the old tumbler and insert them into the new tumbler. This is a delicate process, and might not be worth the hassle to you.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-30-2013, 04:11 PM
ignition
To add to Petriej's comment the diagram I gave you was for a 1995 M3 made in January. I have never had realOEM give me the wrong part number.
Old 07-19-2013, 11:36 AM
RockyTop316 RockyTop316 is offline
I bleed Orange.
Mein Auto: 1996 316i
(*sigh*) I really don't want to post this.......but the saga of "Victoria" continues.
First thing first, thanks for the diagram, Jon.
Situation: My lock tumbler is bad. I'm having the same problem these cats had (did the free spin thing, went to where the ACC came on, and now the key won't move. It'll come out of the ignition, and the steering wheel will turn), and y'all already narrowed it down to the tumbler (well, Jon did). 1995 316i, by the way. Here's my question. IF....(*and this is a BIG if) I can maybe find one at the local junkyard with the key in it, is it a plug and play thing?? Meaning, can I put the "new" one in and it work right off the bat, or is the chip in the key gonna keep that from happening??
Also, if someone has a PDF of the removal instructions......I'd be eternally grateful.
Originally Posted by another forum
John Moses Browning isn't God, but when God needs a firearm, he's the go-to guy.
ROCKY TOP, you'll always be...home sweet home to me....Good ol' Rocky Top, Rocky Top Tennessee!!!
Old 07-19-2013, 11:39 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The 95s had EWS, right? If so, I think it will work if you transfer the EWS chip in your current key to the donor key.
1998 BMW 328is
1966 Pontiac GTO
Old 07-19-2013, 11:42 AM
I bleed Orange.
If by "EWS", you mean the huge plastic ring around the ignition.....then yeah, I got that. Is the chip pretty easy to get to??
Old 07-19-2013, 12:12 PM
hornhospital's Avatar
D'oh, You Kids!
'95 did NOT have EWS, at least mine doesn't.
Quotes to live by:
Old 07-19-2013, 12:17 PM
I bleed Orange.
Would me posting a pic of my key and ignition be of any help??
(*crap, forgot to mention that mine's euro-spec, if that matters*)
Old 07-19-2013, 12:18 PM
D'oh, You Kids!
It might help. To both the info and picture.
Quotes to live by:
Old 07-19-2013, 12:59 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, EWS is the security feature which pairs the car's ignition to the key. If there's a plastic ring with a wire connected to it, you have EWS. I've never swapped the chip before, but I bet it isn't that hard. There's probably some info online about how to do it.
1998 BMW 328is
1966 Pontiac GTO
Old 07-19-2013, 02:05 PM
D'oh, You Kids!
"tire connected to it"?
I know you meant wire, Karl. May want to edit that or someone might get seriously confused!
Quotes to live by:
