E46 (1999 - 2006)
Old 06-01-2013, 09:00 AM
wheeler000 wheeler000 is offline
Mein Auto: 2003 330xi
first gear slow to engage on cold start.
two mornings in a row this has happened. I have not done the transmission oil change so I would not think it is a fluid issue unless I have an undetected leak. the e46 fanatics page says it could be normal but there is no way this is normal. they also mentioned a solenoid not building pressure and or a software issue. all of this sounds great to me since no one mentions it being anything major. it just became hot outside I wonder if this could have anything to do with it or is it that sensor somewhere in the car that says you just fixed a bunch of stuff for now it's time for something else to break.
"I wrote them a letter that said I'll never come home, but did not send it and wrote it again and again; stacked up to the ceiling, and then another stack, and burned them all winter for heat."- Steve Albini
Old 06-01-2013, 09:07 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
You might have answered you own question...ATF is not "Lifetime Fluid" (an idea which has been pimped by BMW for 15 years now). Try a drain & refill (no Power Flush) and see if there`s any improvement.
The road goes ever onward....
(R.I.P. Jever)
Old 06-01-2013, 09:58 AM
hey Bob thanks. I wonder how much time I have to get to this. one of the reasons I tried DIY because I do not have time during the week to take my car to a shop but I have no way of getting my car off the ground at home as I'm sure is a problem for almost all of us so I would have to have this done professionally. am I in danger of injuring the transmission if I procrastinate?
Old 06-01-2013, 11:14 AM
Fast Bob's Avatar
Keeping it surreal
[QUOTE=wheeler000;7623502]hey Bob thanks. I wonder how much time I have to get to this. one of the reasons I tried DIY because I do not have time during the week to take my car to a shop but I have no way of getting my car off the ground at home as I'm sure is a problem for almost all of us so I would have to have this done professionally. am I in danger of injuring the transmission if I procrastinate?[/QUOTE]
Let`s just say "The sooner the better"....
(R.I.P. Jever)
Old 06-01-2013, 11:41 AM
the more I look into this it sounds like the old no reverse problem but substituting first for reverse. since it drives good as new wanted to just even a little bit warmed up I'm thinking this solenoid thing sounds very much like the culprit. something about the screen being clogged. I think my next cold start I'm going to go ahead and put it in manual and see what that does.
Old 06-23-2013, 04:36 PM
update: my car stoped doing all of the above for the last 2 or 3 weeks now until today when it sat in 90 degree heat for about 32 hours without being driven and it decided to slip through two or three gears within about an eighth of a mile and then it was fine. I'm not sure what to think other than just keep monitoring it.
Old 06-23-2013, 06:01 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Did you do the fluid change as suggested? How many miles?
Transmissions are better served when you look into symptoms as soon as you can. If the clutch packs are indeed slipping because of really contaminated fluid, or maybe low level, addressing it sooner rather than later will be best. When the clutch packs get glazed over from excessive slip for example, you now have another issue. When it starts slipping you also generate more heat, at the risk of hardening the piston seals. Any yet another issue.
You'll have to be proactive with this one. Get something to scan your transmission codes, and in the meantime think about doing a D&F on that fluid. At this age, you'll want to verify the fluid level anyway.
Old 06-24-2013, 06:38 AM
is there a traditional linkage on these transmissions,...the steptronic automatic? this is my theory and the reason I ask: if there is a linkage then I guessthat the hot weather might expand the metal and it is not actually getting into drive. I'm just trying to figure out why it would be intermittent to the extent of it slipping once in 3 weeks. what is it about the fluid that could cause this to happen? if it's low or dirty it's constantly low or dirty, right?
