Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 06-02-2013, 01:19 PM
fobeke28 fobeke28 is offline
Mein Auto: 1986 535i e28
'86 e28 power windows not working
So this is my first post, I'm new to this site
I have a 1986 535i e28 and the windows stopped working, where can I look to solve the problem?
Old 06-03-2013, 08:46 AM
msam1911 msam1911 is offline
Mein Auto: 1988 BMW 535is
Skip to 17:00 minute mark on this Wheeler Dealers video to see what's up with your windows:
http://www.streetfire.net/video/whee...rbo_635329.htm
It worked on the back windows of my '85 528.
Old 06-04-2013, 04:57 PM
catso's Avatar
catso catso is offline
catso
Many times window problems are either the switch or a fuse. If it's just one window, the switch is likely the problem. Confirm it by switching the bad one with another switch. You can buy replacements pretty cheaply or even repair the problem by taking the switch apart and cleaning up the corroded contact points.
![/I][/FONT]
Old 06-07-2013, 09:40 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
msam1911's link is to Wheeler Dealers - S01E03 - Saab 900 Turbo, so not much help there. If the windows all stopped at the same time I'd check the circuit breaker on the right side of the panel below the steering wheel - it might have been inadvertently pressed.
Old 06-12-2013, 05:47 PM
John in VA ive pressed that button many times but it doesnt seem to do anything, the only fuse box there is in the car is under the hood right?
Old 06-12-2013, 07:39 PM
catso's Avatar
catso
The power window fuse is #6, under the hood. The power window relay is located on the relay panel, under the dash, by the hood release lever. Fuses sometimes appear to be OK, when in fact they are cracked or warped and current does not flow. Try checking with a volt meter.
![/I][/FONT]
HTML code is Off
