E46 (1999 - 2006)
Old 06-03-2013, 09:53 PM
whinojosa's Avatar
whinojosa whinojosa is offline
Mein Auto: 325i W/O CDV
Excessive tire noise - Michelin PSS
Hey all,
I've been noticing a very very distinct tire noise at speeds above 35-40. It's pretty loud while going straight or lightly turning. The strange part is that the noise noticeably subsides while making a sweeping right turn. Think of a wrap-around on/off-ramp. I can't say definitively, but I think the noise remains on left turns. it seems to go away only on right turns.
Obviously this is pointing to something off with the alignment. I've done tons of front end suspension work - its basically brand new. I've got H&R sways (set to middle-stiff), the touring cup kit, RE poly CABs. The rest is stock replacements (tie rods - inner + outer, CAs, sway bar links
I had an alignment done after the CAs and tie rods in late November 2012. Put the PSS tires on in Jan I think. Did not get it re-aligned after tires.
Before I take it to get aligned again, just wondering if anyone else has pretty significant noise from their PSS tires. It's noticeable and actually affects conversations inside the cabin. Also what tire wear characteristic, if any, would cause this noise? (I.e. cupping, feathering)
It's very disheartening to know I've basically got a brand new front end and am having alignment issues. Grrrrr.
- Will
Los Angeles BMWCCA Member#415991
Old 06-04-2013, 08:18 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Sounds like wheel bearing to me.
Jeff R.
Old 06-04-2013, 08:41 AM
SPDSKTR SPDSKTR is online now
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
Agreed.
Old 06-04-2013, 09:28 AM
isherwood isherwood is offline
Has no parade mode
Mein Auto: Mystic '04 330i ZHP
I'm rolling on Pilot Sports and was also wondering about a moderate buzz/hum when approaching stoplights. It's not unlike the sound my winter beater Alero made when its front bearings were shot, but that got worse with speed. With the Bimmer, it fades with speed and is no longer noticeable by about 30 mph.
I see that the fronts are scalloped a bit and wondered if I'm just hearing the large treadblocks smacking asphalt. What do wheel bearings sound like on these cars?
Old 06-04-2013, 09:29 PM
whinojosa's Avatar
Thanks guys. Would there be any excessive irregular tire wear as a result to check which bearing would be bad? Or, is the fact that the noise subsides when turning right an indication of which bearing to check?
I'll do a little research here on checking for bad bearings a little bit later. Just throwing the above questions out.
- Will
Old 06-04-2013, 11:37 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Correct, bad right bearing, as evidenced by the subsiding noise when that side is unloaded.
Front or rear is a tougher guess because the sound resonates and seemingly comes from all directions, but if its REALLY loud and booming I'd say its the rear.
Old 06-05-2013, 02:39 PM
whinojosa's Avatar
Thanks all. Today, i had my buddy listen closely as we drove in to work today. On a slight right-handed freeway transition, immediately upon straightening the steering wheel - the noise resumed (after the right turn). Also, it gradually came back on as the steering wheel centered. There was no audible lag, if that makes any sense. It seemed directly correlated. Is it possible this lack of delay is an indication of a bad front? Just throwing ideas out there.
I won't have time until this weekend to get it in the air and get the calipers off to check for sounds. At least i know it's definitely the right side!!
- Will
Old 06-06-2013, 11:08 PM
When I diagnosed mine, I took it on a nice even and long freeway stretch. Transferring the load front to rear with braking and accelerating will give you some clue, but I remember thinking at the time that it's still a guessing game.
Bring an extra set of ears to your run. Do several cycles and don't share your "findings" to each other until after you complete the runs.
At the end of the the day it will still be a guess, albeit an educated one. And at least on my coupe, there was no way I could tell the bad bearing on a lift where there's no load. You yourself said the sound went away when unloading the wheel on a turn.
Old 06-07-2013, 11:30 AM
slowlanemcvane slowlanemcvane is offline
Mein Auto: E46 325i
Checking wheel bearings is relatively simple. Jack up the car. Place it securely on jack stands. Grab the wheel at the 12 o'clock and 6 o'clock positions and attempt to rock the wheel in and out. If there's any play that you can see or feel, then you need to replace your bearings.
Old 07-24-2013, 01:17 AM
whinojosa's Avatar
Ok, so I swapped out the front right bearing. 200 ft/lbs is crazy to remove!! I basically put my entire body weight and had to jump onto the breaker ratchet to break the nut. My first experience with anything that tight.
In any event, the excessive noise remains. It exhibits the same characteristics as before, which is the fact that the sound reduces or goes away altogether when turning right. Again, an indication of a bad bearing on the passenger side. Obviously at this point there is only one option left: switch the passenger rear bearing. It's obviously harder to do than front as front took me about an hour.
Having all my symptoms, does it still sound like the bearing? Anyone else having issues with Michelin PSS noise?
- Will
Old 07-24-2013, 06:03 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
I'm running PSS all around w/o sound issues on my ZHP.
Did you check your alignment specs? May be running too much toe or out of spec camber n caster.
Also, running stiffer bushings does add to the vibrations felt and a slight amount of noise but not bad enough to be heard in the cabin.
Try dialing your swaybars to the softest setting this may also help.
On the tie rod replacement did they make sure the length was properly adjusted to match the previous ones?
Old 07-24-2013, 08:01 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
No reason everything new would preclude needing an alignment.
I have H&R sways with poly CAB's too. Have Michelin Pilot Super Sports on my front end too.
Have no issues with noise from them whatsoever.
Love these tires. Cannot think of a tire I'd rather own.
How do you deal with high performance summer tires in winter? Never snow where you are in CA?
Old 07-24-2013, 08:48 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
It is your REAR wheel bearing.
Old 07-24-2013, 10:18 PM
whinojosa's Avatar
Thanks for the response. Nice to be able to eliminate the tires themselves with an almost apples-to-apples setup.
Sunny SoCal!! Snowed once back in the 90's. Hailed a few times here and there but definitely don't have a need for winter capable tires.
- Will
Old 07-24-2013, 10:47 PM
whinojosa's Avatar
Yes. I'm probably leaning toward this. Not lookiung forward to this one. I'll need tools as I'm no Smolck http://www.bimmerfest.com/forums/sho...598&highlight=
I'll get some quotes from the BMW CCA recommended shops around here too. I'm no strange to wrenching on this car, but this one worries me - prob just the daunting cost of specialized tools.
I'll keep this thread posted.
- Will
Old 07-25-2013, 07:45 PM
smolck's Avatar
ROLL TIDE!
A couple guys on E46fanatics rent the press you need. With that, the job is easy. Even with the rental you'll save a bundle over what a shop would charge you. I highly recommend you replace the hub with a new one while in there. Do it once correctly, and then never worry again.
Old 07-25-2013, 08:56 PM
whinojosa's Avatar
Funny you mention that... I'm probably gonna grab the rtab told from "Mango" from E46F tomorrow or Saturday. Unfortunately I didn't buy rear bearing or hub. Oh well, he's not too far from me. I'm definitely not going to buy the bearing / hub from the dealer.
- Will
Old 07-25-2013, 09:07 PM
smolck's Avatar
ROLL TIDE!
The RTAB tool might not do you any good since we are talking abour rear wheel bearings though........
Old 07-25-2013, 09:51 PM
whinojosa's Avatar
Hahahhaha I know that!! Just finally getting around to my Rogue RTABs for which I'm renting the tool from Mango who has the wheel bearing tool for rent as well. im already making a trip to grab the RTAB puller - it would have been nice to rent the wheel bearing tool set and do it in one shot if I had the bearings on hand.
- Will
Old 07-26-2013, 08:31 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
What are your alignment specs, both F and R? I'm presuming you checked your tires, but just in case, run your bare hand on the tire surface, outside, inside and center for unevenness.
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 07-26-2013, 08:35 AM
smolck's Avatar
ROLL TIDE!
Mango is not my favorite person.
You don't really need the tool though, a drill and air chisel will remove the old RTAB's nicely. The rogue do not require a press to re-install. You will love the feel of the car when done.
Old 07-26-2013, 02:15 PM
whinojosa's Avatar
I have run a super-technical "feel" test and everything feels normal. I had it 4-Wheel aligned late last year after new tie rods/CA's. this was prior to new tires and not been done since the news tires went on. I'm doing RTABs this weekend and getting it aligned again, i'll just spring for 4-Wheel.
I"ll update the thread with results from that in relation to the tire/bearing noise.
- Will
Old 07-29-2013, 07:19 AM
tvr1979 tvr1979 is offline
Mein Auto: 2005 330ci
To answer your question about the PSS's. They howl like mad at low speeds when they are well worn. I have two sets of front wheels, both have PSS. The new tires are quiet, the old rumble less than 10mph.
Old 07-31-2013, 07:42 AM
whinojosa's Avatar
Well... Swapped out the RTABS over the weekend. I switched to Rogue Engineering Poly. They simply press in by hand. Rear suspension is tight again!!
As far as the noise, it seems more pronounced now. It is hard to have a conversation in the car now. Its the rear bearing for sure.
I'll update when I get around to doing the bearing.
- Will
Old 07-31-2013, 07:43 AM
whinojosa's Avatar
I mostly howl/rumble at speeds over 30mph. I'm 100% positive it's the bearing and not the tires. Thanks though!
- Will
