Old 06-04-2013, 09:32 PM
lamarselby lamarselby is offline
Mein Auto: 740 il
2001 740il tuneup
hello..is it a simple task to do your own tuneup?
Old 06-05-2013, 03:59 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
No more or less than most cars as far as the basic stuff, plugs, filters, oil, etc. But what most other cars don't have is e38.org. Scroll down the left column to 'Maintenance'. If you choose to change your cabin recirculation filters under the dash, it helps to be a contortionist but even that isn't too bad on your model year. It's one of those things you don't notice until you notice more air flow after changing them.
http://www.bimmerboard.com/forums/posts/348259
Old 07-14-2013, 09:02 PM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
When us old school blokes used to talk about doing a 'tune-up' we'd be setting valve clearances, cleaning and adjusting points and plug gaps, and adjusting the idle speed and accelerator pump throw.
'Servicing' the car involves changing oil, filters and plugs etc. - routine maintenance. Then there is repairs such as replacing parts, gasketsand hoses, and more major surgery such as engine and transmission rebuilds.
So with O2 sensors and electronic engine management systems, platinum-tipped 100K spark plugs, and coil-pack ignition systems, there is nothing the average punter can do to 'tune up' these cars.
However with a Bentley manual and additional information from sources such as this forum and E38.org, routine maintenance and even more extensive repairs are within the reach of reasonably intelligent BMW owners in possession of a good tool kit.
So the answer is yes / no / maybe, depending on what the actual intent of the question was.
Old 07-14-2013, 09:11 PM
Mein Auto: 740 il
thnx..i managed to change the plugs with ease. now onto the brakes.
HTML code is Off
