E36 (1991 - 1999)
Old 06-05-2013, 03:30 AM
diddy123 diddy123 is offline
Mein Auto: E36
Question smoke from exhaust
I have white smoke coming from my exhaust when starting my car up after a couple of minutes the smoke has gone and the car runs fine without any problems i have done a pressure test and its fine there is no 'gunk' please does anyone have ideas im stuck !!!!
Old 06-05-2013, 03:42 AM
1995BMW325i 1995BMW325i is offline
Lift Heavy - Drive Fast
Mein Auto: 325i
You most likely have a blown head gasket.. The white smoke is coolant burning, does the car overheat?
Old 06-05-2013, 03:51 AM
Mein Auto: E36
No it does not over heat i origanally thought head gasket but im not losing any water or oil and there is no gunk at all present i have also checked my plugs as i was told at least one of them would look clean but they all looked the same and they wasnt clean !!!! the smoke only appears on start up then vanishes some days there is no smoke but other days there is one big puff of smoke and once it clears it is fine !!
Old 06-05-2013, 04:00 AM
Mein Auto: 325i
Check your coolant fluid level. Your plugs are probably fine. Your dipstick probably won't show a thing, make sure your RADIATOR is holding coolant. If the car is not overheating then that is weird...
You live in a bad area? The reason i ask is your gas could be junk.. Don't go to Arco...But generally white smoke is coolant burning. You probably don't want to here this but you more then likely have a small tear in your head gasket. You could try an additive but that will only last so long. It takes a small amount of coolant to puff out white smoke. DO NOT ACCELERATE your BMW hard, you will further damage it.
How many miles?
Btw do a compression test and cyl leak test..It could be but probably isn't your cat (do you have a check eng light..?).. You need engine tests done my friend.
Old 06-05-2013, 05:50 AM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
It is normal for your car to have white smoke come out of the exhaust on start up in the morning. It is the condensation in your exhaust system evaporating.
Old 06-05-2013, 06:08 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Ding Ding Ding!!!
And if you remove the oil cap, sometimes you will see white stuff. It is a process called emulsion. It is just condensation. If you let your car sit for longer, you will have a lot of white stuff under the cap, which is what I see all the time with my M3 when it sits for one or two weeks.
Just start it up, let it smoke, drive around, and you're fine. Until you start seeing little globules in your coolant, just drive the car and have fun.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 06-05-2013, 08:17 AM
Mein Auto: E36
Im 50 50 about it being head gasket because other than the white smoke there are no more signs !! i have had my bmw about 5 years and never had this problem but about 4 weeks ago a load of white smoke started coming from it when starting it up !! I have done all the tests you can think of and they are all fine ....If it is just condensation is there anything i can do to reduce or stop this as there is a fair bit of smoke
Old 06-05-2013, 08:21 AM
hnaz's Avatar
BMW CCA Member
Drive it more often and longer trips. Avoid stop and go traffic as best you can. You could also drive the car harder and clean up the catalytic converter and carbon deposits in the engine as well.
My Previous Work:
Old 06-05-2013, 08:40 AM
Mein Auto: E36
Thanks i drive it nearly every day for work which is about 15 miles each way i will give it a clean up and see if that helps thanks for your help
If that does not work would it be worth doing the head gasket just in case or would i be wasting my time and money !!
I have also thought of the option of putting a new engine in but not sure if this will be a good idea as its always a risk
Old 06-05-2013, 08:54 AM
hunter94 hunter94 is offline
Mein Auto: 1993 BMW 325I
smoke from exhaust
If your not over heating, losing coolant, or losing oil, play it by ear. It sounds like water is building up in the exhaust system. Do you live in a humid/wet environment?
Did you get your engine compression tested?
Old 06-05-2013, 09:49 AM
Mein Auto: E36
I live in the UK so weather is very odd !! one minute its hot then its cold !!!!
Yes had a compression test which was fine not losing any compression !!
Old 06-05-2013, 09:57 AM
hnaz's Avatar
BMW CCA Member
Ahhh yes, temperature changes do that too. It is like that here in the Mid-Atlantic region of the US as well, especially in my state. When it transitions from hot and cold and cold to hot (the weather that is), I notice condensation increases.
It is normal and you're fine. Don't worry about it. Just enjoy the drive!
My Previous Work:
Old 06-05-2013, 09:58 AM
smoke from exhaust
Okay, that's a good sign.
I would recommend to keep driving the car and check the oil and coolant level often. And make sure to make note of both the fluids coloration. I'm positive your engine is fine but its better to be safe than sorry.
Oh yea, and welcome to the fest!
Old 06-05-2013, 10:15 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
This. Condensation just builds up and burns off. As long as it goes away while driving, your head gasket is fine.
1998 BMW 328is
1966 Pontiac GTO
Old 06-05-2013, 10:50 AM
Burning2nd's Avatar
Under the lift arms
Even if it was a head gasket ... Just drive it , I drove my e30 with a broken head bolt for 6 years before I sold it to some crazy German Gus who put it on a track ... These motors take a beating just don't over heat it , they don't take that sort of beating . You'd be suprized what ou can really get away with for a prolonged period of time
Unless your super Anal about how your car looks or how ou feel about people's perception of you ?
15486372<-----
Old 06-05-2013, 11:04 AM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Right on..depends on where you are and temperature variances day to night, humidity etc.
It is also possible you have some water in the gas...fill the tank, add a "water removal chemical" (several reputable brands out there). If the white 'smoke' does not smell sweet it is condensate.
Old 06-05-2013, 11:39 AM
Mein Auto: E36
Thankyou im not stressing as much now feel more reassured this is great for help and advice you guys have saved a lady a few quid Thankyou
Old 06-05-2013, 11:47 AM
Mein Auto: E36
Thankyou all for your replies what is the water removal chemical i have never heard of this before !! Does my tank have to be completely full i normally have about half a tank of petrol would this be enough for the water remover to work ?? sorry if this sounds like a silly question !!
Old 06-05-2013, 12:08 PM
ZeGerman's Avatar
Warm Leatherette
Although, as I mentioned above, I do not think you have a blown head gasket, I wanted to take a moment to respectfully disagree with the statement above which says that it is okay to continue driving with a blown head gasket (in case others read this thread and take his advice). If you continue driving an engine with a blown head gasket, you seriously run the risk of spinning a bearing and/or damaging the catalytic converter(s), 02 sensor(s), etc. You should never continue driving with an engine which has coolant & water mixed in with the oil. Doing so will take a very expensive HG repair bill and make it even MORE expensive.
1998 BMW 328is
1966 Pontiac GTO
Old 06-05-2013, 12:39 PM
Mein Auto: 325i
Don't do the head if you're not overheating or showing signs of a blown head.
Disregard what i said earlier these guys are right.
Old 06-05-2013, 02:52 PM
Mein Auto: 96 328is
As Z said, catastrophic failure will ensue shortly thereafter if you drive with a blown HG. That being said, you seem to exhibit no symptoms of a blown head. I think is is just moisture in your exhaust system. The only other thing I can think of as a possibility is a dropped valve seat but the car wouldn't run right. Just keep driving with a close eye on things.
Old 06-05-2013, 03:28 PM
evanwray evanwray is offline
Mein Auto: bmw e36 325i
just a quick two penny from Johannesburg. If its blowing white smoke it would cost nothing to check your brake fluid level. If the vacuum seals are going, it will suck brake fluid into the cylinders and blow white smoke with no loss in performance.
Old 06-20-2013, 08:14 AM
myfirstbem myfirstbem is offline
Mein Auto: 330 CI
So I started here looking for solution to the white exhaust smoking during start up of my 330CI. It has 115,000 miles on it and just started having this problem within the last week. My oil levels and antifreeze levels were perfect. Car did start to run a little rough, nothing major. I started to look on the internet for possible causes and came across this forum. So as I read different threads, I read possible causes as:
Condensation..over and over again
Blown Head gasket
Valve problems
Water pumps
Leaking fluids
So I took my 330 to my mechanic to have it looked at. He had it diagnosed in 10 minutes. Said it was a bad CVV (CCV). Very common and after 115,000 should be replaced. Said he would look at the plugs to see if there was oil burns (which would cause the smoke) and if so would replace the plugs. Plugs were fine. He charged me 3 hours to replace it, which I thought was fair. No more smoke and it actually runs better. Search the forums for CVV or CCV and I think it will make sense why there was white exhaust smoke.
I liked this particular thread about CVV
http://www.bimmerfest.com/forums/sho...ht=cvv+failure
This is my two cents. I love this forum. Hope to be able to DIY my 330CI some day.
Old 06-20-2013, 09:43 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Completely agree with this. It is not pretentious or self absorbed to take good care of a car. Its an investment.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
