Old 06-05-2013, 09:32 AM
Stape Stape is offline
Mein Auto: 325i
Expansion Valve
I'm having intermittent problems with the A/C. Sometimes it works (usually when the car is cold) and somtimes it doesn't. The system was low so I serviced it with a can from Autozone. Initially, it worked fine but now it's hit or miss. I've been told the most common problem with this system is the expansion valve and the temperature sensor. The temp is working fine. Anyone had similar problems or have any suggestions?
Thanks,
Stape
Old 06-05-2013, 09:49 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
When you mention low,do you mean low in refrigerant?if so how do you know it was low?If you did check your system with guages and it was low than you have a leak,refrigerant does not evaporate.What model?What year?If you want answers then you must supply the wizards on this forum with information,thankyou.
Life is a Journey,Enjoy your ride.
Old 06-05-2013, 10:18 AM
Mein Auto: 325i
Expansion valve
I appreciate the quick response. I noticed the air stopped blowing cold on a road trip last weekend. I checked the system via the low pressure port (I think this would be the refrigerant) with the guage that came on the bottle I purchased from Autozone. It wasn't extremely low but it wasn't within the triangle they provided in the directions. Initially after I serviced it, it was blowing really cold air like it used too, then on the return trip it stopped blowing cold again. This morning, after I started the car, it was blowing cold again. The compressor kicks on fine. It seems like it works fine when you first start the car.
06 325i, 6speed, sport package.
Old 06-05-2013, 11:11 AM
tony(topaz,SMG)'s Avatar
tony(topaz,SMG) tony(topaz,SMG) is offline
Mein Auto: '11 335i,'88 M3, '15 X5,
You are going to need someone with some A/C experience and a set of gauges (high and low ports) to correctly identify the problem you're having.
Old 06-24-2013, 11:32 AM
Mein Auto: 325i
The A/C would initially work on the car when the engine was cold. After the engine compartment warmed up it would cause the Expansion Valve to get stuck. I have since replaced the valve and recharged the system and everything is working great! Expansion Valve is not to difficult to replace and it cost about $30. I had to pay $50 to have a garage discharge the system before I replaced the valve and then I bought a bottle of A/C Pro from Autozone and recharged the system. The only other item I had to purchase (because I didn't have one) was a socket with a 6mm hex key (also bought at Autozone). There are several models of this valve so be sure that the store orders the correct one for your car. I had to go back to Autozone because apparently their system had four different valves for my car. My suggestion is to remove the valve and take it into the store. It's ok to drive the car, just don't try to turn on your A/C. Hope this information helps. Any questions please don't hesitate.
