The X5 SAV Forum
Old 06-07-2013, 03:40 PM
Spring20 Spring20 is offline
Mein Auto: 2006 BMW X5
Drain for sunroof?
Is there a drain for the sunroof ?? Any help appreciated
Old 06-08-2013, 09:41 AM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
leak
What is the issue a leak? If it is leaking there is a gasket that needs to be replaced....
There is no drain, it sits in the middle of the roof.
Old 06-08-2013, 09:43 AM
Your right. Dont know what i was thinking
Old 06-08-2013, 02:41 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
To keep from getting hoodwinked in the future ...my tip to you is to first, save the URL address and learn how to use the online part databases (http://www.realoem.com/bmw/select.do and http://bmwfans.info/parts/catalog/) so that you can look up any part for your car based on the last 7 digits of your VIN...and get its 11 digit BMW part nbr so that when you go shopping for the part, you can use it to help you get the correct part for your car. The part databases also help you deconstruct/reconstruct your X5 when doing a project...and comes in handy if you get stuck...because it can reveal a hidden screw/bolt/clip etc. ...and you can also cross reference part nbrs to see if they are used on other BMW models.
For instance, I will assume that you have the pano sunroof since you have an 06 model year listed...so if you look at the diagram below (and click the link to get the 3 part nbrs ...the 2 drains in the rear are the same, but the front left/right drains have different part nbrs)...you'll know that your pano sunroof does indeed have drains that will move water that infiltrates the sunroof's cassette area and drain it to the exterior of the vehicle:
(see #12 - two drains in front, & two drains in rear)
http://www.realoem.com/bmw/showparts...62&hg=54&fg=05
Q {BMW CCA Member #191509}
(SOLD)
Old 06-08-2013, 06:45 PM
Thanks bro
Old 06-09-2013, 04:41 PM
Drain for sunroof?
Nice work! I spoke to fast
Old 06-09-2013, 05:37 PM
Now you know there are drains
Old 02-24-2014, 09:35 AM
bimpower bimpower is offline
bimpower8
Mein Auto: BMW
My drain tube (passenger side) were pinched in the front, causing the water overflowed. Apparently it was not routed correctly, along side of the visor as opposed underside of the visor. Overtime, the heat had worked itself and causing the rubber to closed tight. Once I re-route the tube to its proper location and reset the pinched rubber tube, I was fine and glad to see water flowing to the outside/underbody.
You may want to check the tubes before changing the gasket/seal.
