Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 06-07-2013, 08:54 PM
ckplays ckplays is offline
Mein Auto: 528e
O2 sensor causing problems
I've got a 1986 528e that's giving me problems. My friend and I just had the whole engine apart to change the head, #5 piston, and the broken timing belt that caused all the destruction. Now that it's all back together, the engine runs great... but only with the O2 sensor disconnected.
Here's a list of the things we've tried:
- Replaced O2 sensor with a BRAND NEW one. (No improvement)
- Cleaned and tested throttle position sensor (just two switches, not a potentiometer)
- Double and TRIPLE checked for vacuum leaks and I absolutely assure you all that there are NO VACUUM LEAKS!
- Ultrasonic cleaned and tested all fuel injectors (they are fine)
- New fuel filter
- No kinks or restrictions in fuel line
- Tested idle air bypass valve and checked adjustment (its fine)
- While motor was apart all valves were checked for leakage and rocker clearances set to .012" as specified.
- New spark plugs, wires, and cap. Has a healthy spark.
- Compression check shows all cylinders exceed the minimum spec 144psi (180-200)
Once again, the engine runs great with no O2 sensor. But with it connected the engine runs extremely lean and barely has enough power to move the car at low-mid rpms. It picks up a bit of power at 4000+ rpm, but not much.
I would just run it with the O2 off, but it needs to be smogged now and (although I do know a guy), I want to do it LEGALLY.
Any idea what is at fault?
Old 06-07-2013, 11:33 PM
catso's Avatar
catso catso is offline
catso
As a guess, I'd suspect the Air Flow Meter.
![/I][/FONT]
Old 03-03-2014, 05:25 PM
zackkcaz zackkcaz is offline
Mein Auto: 88 535i
Bump!
What was the issue??
AFM? o2 sensor?
HTML code is Off
