The X5 SAV Forum
Old 02-23-2008, 01:01 PM
xulsu xulsu is offline
Mein Auto: 2002 325i, 2002 X5
need help replacing low beam headlight
I've searched the forum, found a few articles about replacing the turn signal but nothing on replacing the low beam. the hi beam is really simple and the turn signal seems easy enough. but do i have to remove the auto level mechanism ( I guess thats what the black round casing is) to change the low beam? even the manual makes it look super easy. HELP
btw its a 2002.
thanks!
Old 02-23-2008, 01:59 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
3 screws in the round housing and also pull off the "U" shaped clip on the rubber "bellow" cover will reveal the rear of the light unit. Twist lock connector on bulb and bulb high voltage connector. Replace bulb, twist lock the holder and connector and button up the 3 screws.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 02-26-2008, 12:53 AM
thanks Zulu that worked perfectly until I realized the 14.99 halogens wont do any good when i have Xenons... $117 for a replacement bulb here I come!
Old 10-26-2009, 03:27 PM
mdcline mdcline is offline
Mein Auto: 2009 X5
Getting ready to do the same thing on a 2005 X5. It has the Xenon bulb as well. Was this an easy fix?
Old 01-09-2010, 11:48 AM
leonid leonid is offline
Mein Auto: BMWx5
I'm trying to change low beam xeon headlight bulb on the driver side of my 2002 X5.
Out of the three screws that that hold round housing for the low beam, the bottow screw is especially hard to reach (passenger side is easier) - do I need to remove other parts to get to the screw, or it is easier to remove the entire headlamp assembly to work on it?
Thanks in advance,
Leonid
Old 01-09-2010, 12:21 PM
Zulu95's Avatar
Once you have done it removal of the entire headlamp is a 5 minute job. (Pre-facelift!) Check the home page on x5world for articles describing the process.
Old 01-09-2010, 05:03 PM
Mein Auto: BMWx5
Worked like a charm, many thanks for help!
Old 02-01-2010, 10:45 AM
m5james's Avatar
m5james m5james is online now
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
You can get brand new HID bulbs online from either www.ddmtuning.com or www.hidextra.com for around $50 shipped. Who buys that stuff from the Stealership anymore?
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 02-01-2010, 11:23 AM
E92-Lighting's Avatar
Mein Auto: 335i
we are fully stocked with all HID bulb replacement for all BMW's
http://www.e92-lighting.com/catalog/...BULB-24-1.html
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 02-01-2010, 12:03 PM
m5james's Avatar
HID bulbs aren't BMW specific, so being 2-3x as much as HIDextra.com and w/ free shipping, of course you have plenty in stock. I didn't even look at DDM's prices yet.
INTERIOR:
Old 12-18-2016, 06:37 AM
ljournet ljournet is offline
Mein Auto: X5
X5 (E53) Headlight Bulb Replacement; Xenon or Halogen?
My 2002 X5 driver-side low beam is inoperative (dash icon told me so)! How do I tell if I have xenon or halogen bulbs? Will either bulb work as a replacement?
Old 12-18-2016, 12:15 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
If you can't tell the difference between halogen and HID (high intensity discharge) bulbs...have you decoded your VIN, yet? If you have Xenon (HID) headlights...I believe the option code is S522. Click this link and type in the last 7 digits of your VIN: https://www.bmwvin.com
Or...if a previous owner upgraded to aftermarket Xenons...do you you see a ballast and/or warning sticker/label on your headlights (that indicate HID lights)?
Examples:
You can see the yellow high voltage warning on the HID ballasts:
Q {BMW CCA Member #191509}
(SOLD)
