Old 06-09-2013, 01:10 PM
Nova2k7 Nova2k7 is offline
Mein Auto: 3.0 Z4
Angry Z4 Lots Of Lights On Dash
ok so this starts about 12 months ago when one day i got in the car and put my foot on the break and the car didnt idle correctly! the revs jump widely up and down and sometimes almost stall!! ive also noticed that when my foot is on the break pedal and the gas peddle is pressed the car does not rev?? the rpm just slowly climes to about 1200rpm and then stops, then as you take your foot from the peddles the cars rpm drops so that the car almost stalls. now during this time ive had no lights on the dash and once the car warms the symptoms are less. sometimes at lights when the breaks are pressed the rmp climbs to 1000rpm and the drops once the breaks are released. now from the research ive done over the last twelve months ive been led to think this could be an issue with the break servo? although my indy says all the lines to the servo look fine and cant see any leaks which could cause a vacuum leak!
video
now today i was coming home and had some of the following lights come up!
im now completely stumped as to what the problem might be and where to start looking to get this resolved!_a_
Old 06-11-2013, 02:02 PM
Living Dead Living Dead is offline
ZEDHEAD
Mein Auto: 2015 sDrive35is
I've had a similar experience with a dash of many lights and rough running in my 2006 3.0i, the ultimate solution was to replace the ECU which had fried itself and the car was in limp home mode.
“Thou art to me a delicious torment.” Ralph Waldo Emerson
Old 06-11-2013, 02:04 PM
Mein Auto: 3.0 Z4
The car itself runs fine! Pulls like a train! This only happens when the breaks are applied!
Mods - Stubby, Clear Break Light, Clear Indicators, Clear Rear Lights, sprayed Grills & GapTech Mod!
Old 06-11-2013, 02:44 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by Nova2k7 View Post
... only happens when the breaks are applied!
Brakes.
Old 06-11-2013, 08:36 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Long shot here: I've heard of the trunk lid wire harness having several broken wires right at the hinge that causes some strange behavior when the brakes are applied. You might want to open the rubber sleeve and have a look. BMW also recommends removing the middle plastic clip on that harness.
Old 06-12-2013, 12:30 AM
Mein Auto: 3.0 Z4
I would never of thought of this in a million years! Not sure how I go about checking that lol
Old 06-12-2013, 04:20 AM
vintage42's Avatar
BMW CCA 1405
... BMW also recommends removing the middle plastic clip on that harness.
That would be Post #5 in this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=609801
... Not sure how I go about checking that lol
Some people cut the sheath of the harness to inspect the wires, to look for bare insulation or breaks. Be careful, as it is possible to cut a wire as in Post #11 in this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=511230
Cutting the original rubber sheath then exposes the harness to water. I would first try to pull the ends of the rubber sheath out of the body, and move it back and forth on the harness to expose the wires for inspection.
