Old 06-10-2013, 09:34 AM
leo2302 leo2302 is offline
Mein Auto: 2004 330i
Please help! Trunk won't open
I need to figure out how to open my trunk. Please watch video:
My rear seats do not fold down. How can I get my trunk open without damaging my car? Is there any kind of cable I can pull to get it open? As you can see in the video, I already tried the valet key, but it only turns about 45 degrees and then gets stuck. Any other suggestions??
Old 06-10-2013, 09:48 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
I see you pulling up on the trunk,have you tried pushing down while turning the key?Do you have lots of stuff in your trunk?No dead bodies I presume....
Life is a Journey,Enjoy your ride.
Old 06-10-2013, 10:22 AM
I do have a lot of stuff in there, but no issues before. I'll try pushing down while turning the key. The problem with the key is that it only rotates about 45 degrees (won't turn the full 90 degrees to open)
Old 06-10-2013, 11:50 AM
No luck pushing down. And no dead bodies either
I am getting desperate though. Is there no cable or something I can pull to unlatch the trunk? I know about the one on the inside, but that doesn't help, as my seats don't fold down.
What would the dealer do differently?
Old 06-10-2013, 12:05 PM
3two8iguy's Avatar
I can hear it click so the fuses are good,there were posts about this problem on this forum back on 2-8-2011,read up on them and see what happens,sounds to me like the mechanical part of the electrical release is failing,good luck my friend,let us know what you find.
Old 06-10-2013, 12:20 PM
3two8iguy's Avatar
Check out youtube "BMW E36 trunk lock fix" it might help to keep it from happening again after the trunk gets open.
Old 06-10-2013, 01:13 PM
Thanks, found that video.... would try that fix, but first I have to get it opened. Called the dealer and they said $100 for "diagnostic". Asked if they would be able to get it opened, and they said they didn't know. So now I want to exhaust all options before paying $100 and having the dealer tell me they can't open it.
Old 06-10-2013, 01:21 PM
iaebg iaebg is offline
Mein Auto: 328i xDrive Coupe
Have you tried calling a locksmith?
Old 06-10-2013, 01:35 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
Is there a valet switch in the glovebox?
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 06-10-2013, 01:37 PM
Yes, as shown in the youtube video, I tried both LOCK and UNLOCKED position. Nothing
Old 06-10-2013, 05:52 PM
3two8iguy's Avatar
Have you tried a combination of pressing the trunk button just left of the steering wheel while someone else uses the key,as seen in that youtube video it seems like there is a part of the linkage that obstructs the movement,just a guess,let us know good buddy,peace.
Old 06-10-2013, 06:09 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
You may think that this is a joke, but it's not.
It's possible that something in your trunk is jamming the mechanism.
The mechanism is at the back of the trunk. So, get the car up to 30mph and then stomp as hard as you can on the brakes. You want a full on ABS stop. The force of this might be enough to shift whatever is causing the problem.
Hard cornering or acceleration might do the trick too.
You may even want to try doing this while pressing the trunk release button, so long as you do it in a safe place. The combination of the g forces and the mechanism trying to move may free whatever is obstructing the mechanism. Find an empty parking lot somewhere and see what you can accomplish.
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 06-10-2013, 06:15 PM
Here's another idea. The trunk on that car has an escape handle on the inside. It's item 7 in this microfiche.
http://realoem.com/bmw/showparts.do?...77&hg=41&fg=60
Maybe you can get a coat hanger in and snag that handle? I'm not hopeful, though, because you've already tried to activate the mechanism three other ways. I doubt if the handle will have any more success.
Frederic
Old 06-10-2013, 06:17 PM
Here's the last option. Your seats don't fold, but your car has the same frame as the cars that do have folding seats. That means that once the seats are out of the way, there will be an access hole.
It'll be a big job, but you could unbolt and remove the rear seats.
http://realoem.com/bmw/partgrp.do?mo...23&hg=52&fg=20
Frederic
Old 06-11-2013, 06:11 AM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
I am guessing you don't realize this, but the trunk release button is disabled if the car is moving more than a 1 or 2 mph.
Every day I let out one of my passengers to grab something out of his car. I can't tell how many times I have hit the trunk release while slightly costing forward to a stop. Nope, it doesn't do a thing unless you are stopped.
Old 06-11-2013, 07:36 AM
I'll give this a try today, if only because it sounds fun
I do have golf clubs in the trunk of my car, so perhaps something did get jammed in the mechanism.
As mossman mentioned, the trunk release won't operate if the vehicle is moving, so I'll have to wait until after I'm stopped to try again.
Thanks everyone for your help. Will report after lunch today.
Old 06-12-2013, 05:10 AM
3two8iguy's Avatar
Any luck?
Old 06-12-2013, 05:33 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Aha! That is a source of desperation.
But....guessing vehicle was at rest when you tried the valet key. So how to remove the rear seat back. Bolsters out, are mounting bolts accessible?
It is good to work with one's hands. It is a pisser to find there is no pass-through. TXFred, how do you know all seat back frames are the same?
Old 06-12-2013, 10:20 AM
No luck, but it was fun driving fast and hearing all the junk in my trunk move around
Old 06-12-2013, 08:24 PM
Here's what I found on Realoem for the back seats. This is the model of seat that doesn't have a passthrough or folddown option, so I think it's the right one.
http://realoem.com/bmw/showparts.do?...91&hg=52&fg=20
Item 2, Supporting part, backrest, looks like a plastic insert that covers the hole and supports the seat.
Whatever bulkhead lies between the trunk and seats would be part of the vehicle's unibody. It doesn't make sense to build one unibody with a full bulkhead for the non-folding seats, and build a different unibody for cars that have a passthrough between the trunk and cabin. Ergo, all E90's have the passthrough, but some of them cover it with a big plastic panel.
Hopefully the mounting bolts are accessable from the cabin, and not from the trunk.
My only other suggestion is "outside the box." Get a friend on a skateboard with the valet key. Tow him behind the car at 30mph. On the count of three, have him turn the key in the trunk lock while you stomp on the brakes.
Be sure to film this for YouTube.
Assuming he survives the experience, you might get your trunk open.
Frederic
Old 06-13-2013, 04:42 PM
White D White D is offline
Mein Auto: 2011 335d Sport
Frederic
This is what I would try. Def worth a shot, and free
Bottom usually come out very easy, just pull up then out.
Back will be more work, but worth it if it works.
Old 06-14-2013, 11:34 AM
vrmoreno3 vrmoreno3 is offline
Where is the "LIKE" button for TXFred and the skateboard idea. To effin funny.
Old 06-21-2013, 12:14 PM
Figured I'd give an update... So took it to the dealer. Charged me the standard "$99.99 diagnostic". I asked if that would guarantee anything, he said no. So... after a few hours, he calls me back and said that I would need new cabling as well as a new lock actuator. About $1,000. Asked him if he got the trunk open, he said no.
Then I asked him... well, how do you need I need new wiring, and he told me that his mechanic was able to take out the back seats and see something was up. Called him a liar, since I have a sub and had a TON of stuff in the trunk (golf clubs, towels, backpacks, etc), which would have made it impossible for him to see the locking mechanism. He said he would call me back.
After about an hour, he calls me back and says: "you won't believe it, but the guys were able to open it, and it's now working. Doesn't mean that it will keep working, but if you want to get some stuff out of the trunk, now is a good chance.
So picked up my car and sure enough, trunk was working. HOWEVER, I looked at the lock and saw it was cracked on the side (my guess is this is the issue). Bought a new lock actuator for $60 shipped and voila!
Here's a picture:
Old 06-21-2013, 04:15 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
Stealers.. I think it's them that just got busted.
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
trunk
