The X5 SAV Forum
Old 06-11-2013, 11:15 AM
Dex5 Dex5 is offline
Mein Auto: 2004 X5
Transfailsafe, ABS indicator, 4x4 indicator dash lights - recently changed battery
Good afternoon,
I am new to the BMW family (2 months - i purchased an 04 X5 4.4i) and its giving me the blues. The dash lit up w/Transfailsafe, 4x4, DSC, and ABS lights and wouldn't get out of 2nd gear. I made it back to work, turned it off then started it up again, no transfailsafe, went through the gears, no DSC, turned it off again, then started it back up, ABS Brake and 4x4 lights are still on, and its driving sluggishly....Any thoughts would be greatly appreciated...
Thank you,
DeX5
Old 07-02-2013, 06:32 PM
Bimma Lova Bimma Lova is offline
Mein Auto: E36 M3
Ohh my friend I have the exact same issues for months. I had my buddy a BMW Engineer come and check my truck and he said when he plugged his computer into my truck that it stored battery voltage drop which is what cause the car to start shutting things down. All that was required was a new battery.
Old 07-03-2013, 09:47 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
Sounds like an alternator, it's a very common issue with the 4.4l N62 engines. I'm replacing one right now actually for the same exact complaint.
Old 10-07-2013, 01:33 PM
Mein Auto: 2004 X5
Thank you for the replies to my question. I have now gone through 4 batteries. I've had my alternator checked, and the voltage is good. As of now, the problem has not been isolated. I am also hearing, what sounds like, a winding or grinding sound coming from behind the radio/nav screen console once I shut the vehicle down. I've been told that it should stop in a matter of minutes, but I'm not sure that it does, and believe that may be a drain. *note - they had to replace the NAV screen when I bought it back in April. Any guidance would be helpful.
Old 10-07-2013, 02:20 PM
Past Sponsor
Mein Auto: X3
It's the alternator overcharging when it gets hot. It will test good until you check it when the problem is actually occurring. The whining sound can also be caused by excessive AC voltage in the audio electronics. The batteries you are replacing are getting cooked by the overcharging alternator. At the very least, replace the alternator voltage regulator if you don't want to spend the money on a whole new one
Old 10-07-2013, 03:07 PM
Mein Auto: 2004 X5
I will have that checked out as the culprit. Thank you soo much for your insight. I will keep you posted on how it turns out.
Old 10-10-2013, 08:59 AM
The_STiG_US The_STiG_US is offline
Mein Auto: X5 2001 E53
I would agree with BMWOEM1, your alternator is hosing your X5. Replacing the regulator may fix the issue of the fluctuating voltage, but may not fix the reason why the regulator went bad. It could have gone bad from age, but most likely the alternator itself may be bad and may just fry the new regulator given some time. Safest is to replace the whole alternator, but like BMWOEM1 stated, if costs are of immediate concern (alternators are not cheap for BMWs), then the regulator should fix the issue at the moment.
