The X5 SAV Forum
Old 09-30-2013, 06:11 PM
chefxbkuop chefxbkuop is offline
Mein Auto: 2001 bmw x5
how can i pair my i phone to my x5
i have x5 2001 and not sure how to pair my i phone to the car? can it be done.
Old 10-01-2013, 10:26 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Depends on if you have a BT module installed. BMW didn't offer them on the e53 until the 10/04 build date-up...so if you don't have the required pkg from BMW...then you'd need to check into aftermarket solutions:
Q {BMW CCA Member #191509}
(SOLD)
Old 10-08-2013, 02:28 PM
Riggodeaux Riggodeaux is offline
Mein Auto: 2006 X5 3.0 manual
Several aftermarket solutions, consider bavsound.com's version; there are several others, if your goal is to integrate your iphone/ipad into the OEM radio system, not just connect via bluetooth [if you can do that ...].
Old 10-10-2013, 08:47 AM
The_STiG_US The_STiG_US is offline
Mein Auto: X5 2001 E53
Depends, if your X5 has the in-car phone cradle system from BMW already installed, then you can add the BMW BTU module. But like in my case, if you don't have that installed, it's a PIA to try to retro add it to the BMW. Best bet is to go aftermarket, as others had said. Problem is the X5 does not have a mini jack for the stereo system, so most aftermarket systems will be using their own mics and speakers.
