Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 06-12-2013, 02:58 PM
BillTBimmer BillTBimmer is offline
Mein Auto: 97 M3
Oil Pump Failure?
My 97 M3 conked out at idle. It was short a quart of oil , i refilled then when i started it there was nasty clanking. Mechanic said its the bearing on the crankshaft probably caused by oil pump failure. Has anyone heard of similar problems with these engines? 135,000 regular oil changes?? Is it worth fixing it?
Old 06-12-2013, 11:55 PM
7pilot 7pilot is online now
Git
Mein Auto: 90 Ford Tempo
The loose oil pump pulley nut syndrome is well documented.
Having it locked is a frequent recommendation if the various internet buyers guides are researched.
Rod bearings and main bearings will need to be replaced.
m
engine failure, oil pump failure
