Old 06-13-2013, 11:29 AM
Averdi's Avatar
Averdi Averdi is offline
Mein Auto: BMW 325i 2006
Wheel cleaner !
As you all know...bmw get the worst brake dust. I bought the car with awful dots that wouldn't come off. So here's what I did. Before Click image for larger version
ID:	381566 during Click image for larger version
ID:	381567 and after Click image for larger version
ID:	381568. I used sonax. It didnt get everything I'm wondering if you guys have any idea how to remove it all?
2006 325i
Red intake scoops, Red taillights, Red calipers, M3 rep wheels, M bumper, 28% tints, 6000k Angels & Fog lights, clear cornered headlights, Black and White emblems, Smoked side markers
Old 06-13-2013, 11:33 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
The lady that cleans my home does a fantastic job on wheels and she uses sonax,good stuff
Life is a Journey,Enjoy your ride.
Old 06-13-2013, 11:36 AM
Averdi's Avatar
Wheel cleaner !
It didnt get it all off. I'm clueless I don't know how to get it off
2006 325i
Old 06-13-2013, 11:38 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
not to ask a silly question, but you did scrub it after spraying on the cleaner, correct?
if you have a heavy deposit of brake dust, you may need to use claybar or something to remove it, as the brake dust will actually get bonded to the paint
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 06-13-2013, 11:40 AM
3two8iguy's Avatar
Might be etched in
Old 06-13-2013, 11:43 AM
Averdi's Avatar
Wheel cleaner !
Yes. I used a sponge. Like a dish washing sponge. I used the soft side didnt really do much used the hard side and looked like it scratched it a bit :/
2006 325i
Old 06-13-2013, 11:49 AM
3two8iguy's Avatar
You can use muriatic acid,10 cups of water to one cup of acid,add the water first then add acid to water,wear GOGGLES...rinse every 60 seconds,try on a small area first then proceed,good luck.
Old 06-13-2013, 11:53 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
As you all know...bmw get the worst brake dust. I bought the car with awful dots that wouldn't come off. So here's what I did. It didnt get everything I'm wondering if you guys have any idea how to remove it all?
Dots? Don' see no dots.
I slosh wheels from my car wash soap bucket; use a wheel brush. Comes out like brand new.
Old 06-13-2013, 11:57 AM
Averdi's Avatar
Wheel cleaner !
I'm going to have to try that! It seems very risky.
2006 325i
Old 06-13-2013, 11:59 AM
Averdi's Avatar
Wheel cleaner !
I bought the car a month ago. They were on there when I bought them. Guessing the guy never really took car of the rims. But no soap and a scrubber won't do anything. I've tried that a dozen time..even a power washer. They're stained on
2006 325i
Old 06-13-2013, 12:02 PM
3two8iguy's Avatar
Safety First,Gloves and Goggles,use this as a last resort.
Old 06-13-2013, 12:06 PM
Averdi's Avatar
Wheel cleaner !
You have any other options?
2006 325i
Old 06-13-2013, 12:08 PM
OK....
  • Bug & tar remover
  • Phosphoric acid/surfactant[s] wheel cleaner
Some organics diff to remove w/o solvent. Sometimes low pH does the job. Good luck!
Old 06-13-2013, 12:12 PM
Towelie Towelie is offline
Mein Auto: E90 335xi 6MT
Did you try the sonax multiple times, using a brush? Also, try a product like Iron-X (available on line) or a clay bar (available locally at many big box & auto parts stores). Muriatic acid is very powerful stuff and should be used as an absolute last resort if ever, CAREFULLY following all of the instructions including protective gear and ventilation (you may also want to do a test spot first).
Old 06-13-2013, 12:16 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Caution: Keep this stuff off the rotors unless you're going to drive the vehicle immediately after using, it will sit and dry behind the pads and leave some nasty deposits.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-13-2013, 12:17 PM
Averdi's Avatar
Wheel cleaner !
I've tried sonax 3 times a wheel. Might try ironX next. How's that work?
2006 325i
Averdi's Avatar
Wheel cleaner !
OK....
  • Bug & tar remover
And thank you !
2006 325i
Old 06-13-2013, 01:49 PM
DSXMachina's Avatar
Bimmerdex 7.4!
And thank you !
Go to your local super market. Buy a product called Magic Eraser. Spray Sonax onto sponge. Rub. Rinse off.
You're welcome.
Last edited by DSXMachina; 06-13-2013 at 09:20 PM. Reason: Eraser, not Sponge. Thanks Orient.
Old 06-13-2013, 02:06 PM
A1ex A1ex is offline
Mein Auto: F31 330D M Sport
I use Wolfs deionizer to get most of it off then I get the ez brush out with dojo to get anything left over.
Old 06-13-2013, 03:10 PM
3ismagic#'s Avatar
3ismagic# 3ismagic# is offline
HerrDoktorProfessor
Mein Auto: '11 335d
You might also try some polish on a MF cloth. Something aggressive like 3m.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video:
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 06-13-2013, 03:35 PM
Averdi's Avatar
Wheel cleaner !
What's the ez? And also what's dojo?
2006 325i
Averdi's Avatar
Wheel cleaner !
I've tried
2006 325i
Old 06-13-2013, 03:45 PM
Originally Posted by DSXMachina View Post
Go to your local super market. Buy a product called Magic Sponge. Spray Sonax onto sponge. Rub. Rinse off.
You're welcome.
magic eraser?
Old 06-13-2013, 04:45 PM
Heavy build up I use Wolf's Chemical Deironizer v3 then start again with chemical Guys Wheel + Rim Cleaner.
EZ Detailing brush and cloth are my tools
If its not built up and light I use Valet Pro Bilberry as the deironizer on the alloys all the time is a bit ott and light build up seems to go with the bilberry. I then finish of with a cloth and Dodo Juice - Mellow Yellow (its pretty weak but smells good).
Next step is to maybe try a clay bar but I don't like using it on alloys without taking the wheel off. Either way if the black dots and other things do not come off, you have just let it build up too much
Old 06-13-2013, 06:08 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
I suspect Iron-X to be be pretty much the same as Sonax. Same purple aspect. It is very efficient but there is some permanent but small residues on my winter wheels.
Now I have dust-free pads all around.
