Motor Mount Replacement Notes - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-13-2013, 01:50 PM
computerwhiz1 computerwhiz1 is offline
Mein Auto: 2000 323i
I changed my motor mounts that had been in the car for 14 years and 210,000 miles the other day and I thought I would post some of the lessons I learned so that other people don't have to make the same mistakes I did. The job its self is fairly easy, and really the only hard part is getting the passenger side mount to go in.
This is not intended to be a DIY and I am leaving a lot of information out. This is simply a list of tips I thought would help someone doing this in the future.
The engine wants to jack up rolling towards the passenger side of the vehicle. I was jacking from the oil pan rather than using an engine support. Using an ending support would make this job MUCH easier.
The drivers side mount is easy to replace, the passenger not so much.
For automatics instead of removing the fan, just take the fasteners out of the fan shroud and pull it up a bit so that it can move around freely when the fan comes up as you jack on the engine. This will give you enough room. However, you should still keep an eye on things getting caught.
You have to remove the airbox and upper intake boot to get access to the upper bolt on the drivers side mount.
Remove both top bolts first and then jack up the engine. You will notice the engine comes off the drivers side mount, and if like mine, doesn't lift off of the passenger mount much at all.
I had read in some DIYs that you could leave the drivers side mount in place and use it as a pivot point to help the engine lift off of the passenger mount. I tried this and it worked for a bit and then the drivers side motor mount ripped into two pieces. I don't know if this was because the mount was so old or if anything would do this. My recommendation to you is DO NOT USE THE DRIVERS SIDE MOUNT AS A PIVOT POINT. When it broke the engine fell back down onto the passenger side mount almost causing my dad to loose his hand.
Instead of using the drivers side mount as a pivot point I recommend taking the entire passenger side engine support arm loose so that you can move it around and push it up enough to give you room to slip the old mount out and the new one is. Basically instead of worrying about getting the passenger side of the engine high enough to replace the mount, instead loosen the mount arm so that you an move it around enough to get the old mount out and the new one in.
Don't completely remove the mount arm as it will be a real bear to get back lined up and on with such little room to work.
Realize that your new mounts will probably be taller than your old ones so when you put the new ones in they might not just fit back in the same was the old ones came out.
Go ahead and buy the bolts for the engine mounts. Since they are hard to get to, you will probably mar them up trying to get them out.
If you have any questions feel free to post them and i'll do my best to answer them.
Old 06-13-2013, 02:17 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
Good info, thanks for sharing. I have almost 200k miles and I'm starting to look at replacing the mounts.
Old 06-13-2013, 03:57 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Good stuff. Thanks for the write-up!
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-14-2013, 05:14 AM
SPDSKTR SPDSKTR is online now
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
Allow me to highly recommend OEM M3 motor mounts.
Old 06-14-2013, 09:07 AM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Originally Posted by computerwhiz1 View Post
Instead of using the drivers side mount as a pivot point I recommend taking the entire passenger side engine support arm loose so that you can move it around and push it up enough to give you room to slip the old mount out and the new one in. Basically instead of worrying about getting the passenger side of the engine high enough to replace the mount, instead loosen the mount arm so that you an move it around enough to get the old mount out and the new one in.
This. Except I took it all the way off (except for the ground strap). I just set it on the control arm so as not to stress the ground strap. Made replacing the mount really easy, and it wasn't hard getting it lined back up.
Old 12-15-2014, 03:53 PM
Abnormy Abnormy is offline
Mein Auto: 03 325I
did a cooling system refresh last summer and just found the ac belt wore a groove in the lower rad house wondering if it's not the mounts caused it. at work now so will report back soon
Old 12-15-2014, 04:18 PM
Scottji's Avatar
Post a pic of where you think it's rubbing. I'd be really surprised if the motor is moving enough to let the a/c belt rub the hose, but I've been proven wrong before. Also, if it was rubbing, I think it wouldn't take long for the ac belt to rub clean through the hose. Are your pulleys and tensioners good?
There should be several inches of clearance between the belt and the hose:
Old 12-15-2014, 05:41 PM
Mein Auto: 03 325I
I replaced the tensioner and pulley along with the water pump and tstat last summer. I'll post a pic of hose with groove in it tomorrow morning
Old 12-16-2014, 12:09 PM
Mein Auto: 03 325I
Here's the hose gotta get it back up on ramps to see if motors moving on mounts. 140k on car
Old 12-16-2014, 01:07 PM
Mein Auto: 03 325I
Here goes again
Old 12-16-2014, 07:15 PM
Scottji's Avatar
Based on the bend, I take it that's the lower/radiator end of the hose, as opposed to the upper/t-stat end? And I'm assuming the hole for the temp sensor is turned away from the camera in that picture. If so, that means that cut is on the bottom of the hose (and not the side)? Have you driven a lot without your plastic splash guard? If so, I'm thinking you might have hit something that came up and hit that hose. I don't really think there's anything else between that hose and the splash guard.
Old 12-16-2014, 07:53 PM
Mein Auto: 03 325I
You may be right Scott ji I'll recheck it! And put the splash guard back on
Old 04-06-2015, 07:54 PM
DEADF15H DEADF15H is online now
Mein Auto: 2001 325i 4 door DD
I did the mounts using the Harbor Freight Engine Brace. After raising it up, it looked as though the engine wouldn't drop back down on top of the new mount bolts, I was under the car, buddy lowered it, it hit the passenger side first, it went straight right in. I didn't have to take off any braces or support arms, just the bolts and mounts.
It's an easy DIY for a rookie, if you have H.F. wobble extension set for your ratchet, PB Blaster the nuts, then wait an hour, maybe a extension pipe if you have rust underneath, I didn't.
Here's a video from 50's kid, using a floor jack to do it, but he had issues with the engine getting cockeyed and has an interesting solution.
For about $70 with a coupon you can pick up the Engine Brace, I've already had my oil pan gasket reinstalled, so I think it will be awhile before I need it again, but I don't have patience to deal with issues, when all I need is a tool, to make it easy. Plus I can't afford to be without the car.
Anybody in South Florida is welcome to use Engine Brace for free with a $70 cash deposit.
Old 04-07-2015, 04:48 AM
tristero tristero is offline
Mein Auto: 04 330ci ZHP 6MT
Don't completely remove the mount arm as it will be a real bear to get back lined up and on with such little room to work. .
this.
Also, just as a general auto-mechanic "trick"; when you're having a hard time getting a part to line up with bolts on one side, undo the bolts on the other side so they're loose. Get all the bolts at least threaded-in first, so that it leaves enough play for the part to adjust. Then tighten all the bolts a bit at a time until they're snug - then torque-wrench them to the proper tightness.
2004 330Cic ZHP 6 MT. . .
RIP: 1995 525i M50TUB25 Autotragic; 247k miles.
Old 04-09-2015, 01:46 PM
Originally Posted by tristero View Post
this.
Definitely! Don't get in a hurry, it takes more time going back and forth in the short run, pays off in the long run.
engine mount, motor mount
