Z3 Roadster (E36/7) Problems with retractable top - Bimmerfest - BMW Forums
Old 06-13-2013, 02:15 PM
rtbergman rtbergman is offline
Mein Auto: 1998 Z3M Roadster
My wife recently bought a '98 Z3M Roadster. First the brake light didn't work, so I replaced the switch under the brake pedal. Looking back, that was easy to figure out and fix.
We have had issues with the retractable top. The top motor only kicks in sporadically when opening or closing. Typically, when we push the button on the console, nothing happens. Other times it works on the first try. Occasionally, after multiple pushes, it will suddenly work. Next time we try it, however, same results. No obvious pattern. Sometimes it goes down, but won't go up, or vise versa.
The fuse is good, hydraulic fluid level is fine, etc. I replaced the top switch in the console, near the shift lever, thinking that might be the problem, but no such luck.
I've read about the microswitch in the hinge on the left side of the top being a problem. I hear it "click" when it is pushed up, etc. but have no way of knowing whether or not to replace that too. We live about 150 miles from a dealer, so I'm looking for things I can handle myself.
Advice?
Old 06-15-2013, 05:16 PM
I may be on the right track
Found info on this site about relay switches, located in the trunk next to the motor. Took them out (there are 2 of them) and brought them to a local auto parts shop, where they were able to test them. They were dead.
New switches ordered. Will post results.
Attachments show where these are located and what they look like. They are next to motor, in the trunk, between it and the rear panel. Easy to remove.
In the first picture they are at the 10 o'clock position, and are seen just behind the motor.
Old 06-18-2013, 02:59 PM
I believe it is fixed!
Replaced the relays, in the trunk next to the motor, and it works beautifully! See attached pictures. Cost $42 for both. Keeping fingers crossed that this take care of the problem.
ID:	382552   Click image for larger version
Old 06-19-2013, 11:56 AM
Zedfor's Avatar
Zedfor Zedfor is offline
Meinkugelschmerzen
Mein Auto: 2003 Z4, 2007 X3
Aren't these forums great?
If you don't know where you are going, any road will take you there.
ZSCCA
