Old 06-14-2013, 09:38 AM
fabolousarch fabolousarch is offline
Send a message via AIM to fabolousarch
Mein Auto: 745i
745i Shaking after driving 45mph! please HELP!
hello all,
My 02 745i is shaking a lot, the car itself not the steering wheel, after i pass the 45mph mark. its a violent wobble and shake. I thought maybe it needed an alignment which i did this morning and but the shaking is still there.
I checked all the rims and tires, the upper and lower control arms, and breaks.
Can someone help me please
Old 06-14-2013, 11:56 AM
JUBMW JUBMW is offline
Mein Auto: 2003 BMW 745LI
Originally Posted by fabolousarch View Post
hello all,
I see you done an alignment, but did you also have your wheels balanced? I would try that next if you haven't. Good Luck!!!!
Old 06-14-2013, 12:42 PM
Mein Auto: 745i
Thanks JU, Just did the balance as well, still the same problem
Old 06-14-2013, 12:57 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
do you feel it in your seat or in the whole car?
It could be a few things:
1. Bent Wheel
2. Out of balance tire/rim
3. Bad ball-joints and/or suspension parts
4. Out of round tire
5. Bad tire
A good tire shop should be able to figure out if it is the tires, or as well if your wheel is bent. Make sure you go to a shop that uses a HUNTER ROAD FORCE balancing machine as these are the only machines that put force against the tire while it's spinning to truly balance it.
As well I would go to your independent mechanic and have them check out ALL the suspension components.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 06-14-2013, 01:56 PM
dannyb1027 dannyb1027 is offline
Mein Auto: White 2002 745I
This is a longshot but is there fix a flat in one of the tires?
Old 06-14-2013, 04:20 PM
Salmantheman Salmantheman is offline
Ms. AWesome ;)
Mein Auto: E66
hello all,
I faced the same.. one of your rims on the front wheels is bent. change them with your spare on in the boot and you will know which one is the hassle..
normally its the drivers side which is the culprit
Old 10-28-2013, 02:54 PM
Fastpaddler Fastpaddler is offline
Fastpaddler
Mein Auto: 2016 Jaguar XF AWD Presti
Had it happen on a MB 190. Was indeed bent wheel at right front. Aluminum wheels dont like big potholes.
Old 10-29-2013, 06:56 AM
boyette boyette is offline
Mein Auto: 745i04
check rotor…...
Old 10-29-2013, 09:54 AM
mgucci745 mgucci745 is offline
Teenage Car Enthusiast
Mein Auto: 2002 745i
What problems or issues can this cause? My steering wheel shakes when I'm going about 30MPH and I think my wheels still bare to the right after getting front and rear wheel alignment done... (Fix a flat in rear passenger tire) (very small dent in front passenger rim)
This Car Im Driving Make U Feel Some Type Of Way
@V1SUALZ Los Angeles car v1sualz company coming soon!
F*** a lease, drive a e65
arm, bushing, control, driving, engine, motor, rims, shaking
