E30 (1982 - 1993)
Old 06-15-2013, 03:45 PM
Belcher Belcher is offline
Mein Auto: 325i
oil leak?
Anyone know how to fix an oil leak from the device where the oil filter and cooler connect to? The leak is from the lower back corner where there is a quarter size dial of sorts. The dial can be adjusted but makes the leak worse.
HELP PLEASE!!:
Old 06-15-2013, 06:06 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
oil leak?
Forgive me Im not too familiar with the M20 but There should be nothing more than plain o rings sealing the lines to and from the oil cooler on those motors. Is it leaking from one of the lines?
Old 06-15-2013, 06:31 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
Re: oil leak?
A picture would help us help you.
1987 325e automatic sedan
Old 06-22-2013, 08:05 AM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989/1991 E30; 2000 E38
Re: oil leak?
You must remove the snap ring holding in the dial, as you called it. Now just replace the internal o rings. Look at realoem for a picture of the parts involved.
Big Boyz with Bad Toyz.
