Any harm "topping off" gas - Bimmerfest - BMW Forums
Old 06-16-2013, 01:17 AM
Gdiego Gdiego is offline
Mein Auto: 2011 BMW 328I xdrive
Habit I suppose. I add that extra $1 or so and try to record a full dollar amount (no cents). Any harm with this procedure?
Old 06-16-2013, 01:34 AM
aKiwiJoKer aKiwiJoKer is offline
Mein Auto: 540i se
apart from, spending too much money? how could it
Old 06-16-2013, 02:58 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Yes. If you overfill the tank, it will run out the vent line before spilling out the neck. If that happens, you can saturate the activated charcoal in the vent filter canister with gasoline, which can set off an engine code and potentially result in some needlessly pricey repairs.
Just stop when it shuts off. You're likely wasting much of the excess anyway.
Old 06-16-2013, 03:08 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
I would guess it is ill advised because a moment's inattention might result in a gasoline spill. Seems to me, the benefit is miniscule compared to the risk.
Personally I just let it shut off.
Old 06-16-2013, 05:15 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yes. You are obsessive-compulsive and insisting on a dollar amount with zero cents reinforces your behavior pattern.
Required is strict and unforgiving attention to the task at hand. Allow your focus to wander but a little and you can easily overshoot by $0.01....or more! Major difficulty occurs when you realize that you cannot run the pump back. You can only go forward, squeezing in a quarter gallon to arrive at the next even dollar amount.
Beaded with sweat, your hand beginning to cramp, you barely trickle gasoline through the nozzle, eyes wide and locked on the pump dollar amount display....you blink as a drop of salty sweat runs into your eye and you release the nozzle lever so that you do not miss your important goal. On checking the pump again you find you're just $0.02 away from zero cents - you squeeze very slowly - disaster! You again overshoot!
You stand in a widening pool of gasoline as other motorists flee from possible immolation...a psychiatric ambulance screams, weaving through traffic. I implore you, Gdiego, resist this "topping off!" It cannot give you good result, and should be met with strength and resolve. Professional help is available in this regard.
Old 06-16-2013, 05:22 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
Beaded with sweat, you hand beginning to cramp, you barely trickle gasoline through the nozzle, eyes wide and locked on the pump dollar amount display....you blink as a drop of salty sweat runs into your eye and you release the nozzle lever so that you do not miss your important goal. On checking the pump again you find you're just $0.02 away from zero cents - you squeeze very slowly - disaster! You again overshoot!
This is the most coherent post I've heard from you in a while.
Bravo!
BMW CCA Member 454031
Save the manuals
Old 06-16-2013, 06:02 AM
R608 R608 is offline
Mein Auto: '11 328i M-Sport (6MT)
http://www.epa.gov/donttopoff/
Old 06-16-2013, 10:35 AM
Post of the month!
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 06-16-2013, 04:12 PM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Not necessarily obsessive-compulsive. Everyone is "obsessive-compulsive" to some degree. A study was done that found that most people feel uncomfortable when the volume level on a television, radio, etc is an odd number. Take it how you may but "obsessive-cumplusive" is just part of human nature.
I myself also fill my tank up to a solid dollar amount with no change (mainly because I like playing the game to see if I can let off the handle and let it land exactly on $xx.00).
Psychology major, just trying to share my knowledge
However, I do find it odd that you would add an extra dollar once your tank has been "filled". The pump stops when it stops for a reason. As stated above, this can be harmful to your car.
BUT I must admit you are quite the story teller, sir
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 06-16-2013, 05:51 PM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Calwaterboy,man you nailed you nailed it with that one,love reading what you write,like I said,Dickens,Shakespeare etc.....
Life is a Journey,Enjoy your ride.
Old 06-16-2013, 05:55 PM
3two8iguy's Avatar
I have always had a problem with the the trigger on the pump handle resetting like the tank is filled I have to turn the nozzle sideways and pump real slow,cant figure it out...
Old 06-16-2013, 06:01 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
I'm with the clear-eyed Cal.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 06-16-2013, 10:42 PM
I did write a thing for Ms. Kat....
Old 06-17-2013, 05:47 AM
bavariaman bavariaman is offline
Mein Auto: BMW
I did it once...Never again......Gas spilled out and it smelled like gas for a bit afterwards in the car....No real harm done though....
Old 06-17-2013, 05:55 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Dude, you are so in my head! Hilarious post!
Old 06-17-2013, 06:00 AM
Moderator
Not to take a light moment too seriously but adding gas to your tank also creates air bubbles thus the ability to top off your tank as it's not really full. But as we've said, topping off is more compulsive than necessary but if doing so keep the Xanax prescription at a tolerable level than I'm all for it.
Old 06-17-2013, 06:59 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
This is probably diagnoseable ......
Always end the fill up on the odd cents corresponding to that day's date .... .01 thru .31 ..... today's fill up will end with $XX.17 .... that way don't have to look at the credit card bill and wonder did someone get my card at the gas station??
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 06-17-2013, 07:08 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
Add me to the list of OCDs. Maybe we need to reclassify the forum from an e9x forum to a support group... One section for the gas pump challenged and another for those members with goat obsessions.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights - blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 06-17-2013, 07:22 AM
e92josh e92josh is offline
New Guy
Mein Auto: 2009 328i Coupe
We need to get drunk together.
Old 06-17-2013, 01:53 PM
E92-Lighting's Avatar
Mein Auto: 335i
+1. i let it stop.
BMW ACCESSORIES and PARTS
Old 06-17-2013, 02:31 PM
Mein Auto: 540i se
might I also mention the more weight you carry the more fuel you use : making it less economic
I also forgot gas most likely way cheaper than here so takes a bit more to round up nearest US$ than NZ$ hence 1st reply sounds dumb now
Old 06-17-2013, 07:04 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Interesting...but will only contribute to the "OCD" crowd. I DID hear at one time that gas stations were notorious for credit card theft, but I believe that's only if you go INTO the station to have your card swiped...not at the pump?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-17-2013, 07:19 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Thanks a lot. You have just restructured my way of filling up. While totally OCD, I like it. What a cool way to keep track!
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 06-17-2013, 07:55 PM
Kamdog's Avatar
<- Bailey
Fortunately, I am completely oblivious. When it clicks, I pull the hose out, and never look back. I don't even look at the credit card bill, that is my wife's job. She does the paperwork, tells me what to pay, and I sit at the computer and type in the dollar amount of the bills we pay.
It works for us. I never see what she spends on clothes and her stuff, and she never gives me grief on what I spend for gas and my stuff.
Our next anniversary will be our 40th.
Old 06-17-2013, 08:20 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Nicely done, Cal! 'tis quite entertaining, make me laugh, you have!
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
