Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 06-16-2013, 06:12 PM
Quambomb Quambomb is offline
Mein Auto: 2008 328xi
Some questions/concerns about freshly painted calipers
I hand-painted my brake calipers this weekend and am unsatisfied with the result. It put on 2 coats of paint and even though the color is great, it is easy to tell that they were hand-painted and not professionally sprayed or painted - the surface texture isn't very smooth. I believe I'll need to remove a layer of paint and spray paint the calipers to get a better look. What is the best way to remove a layer of caliper paint and prep for re-painting?
Also, I'm curious what to do about the metal brackets that attach to the outside of the brake calipers? Are these usually painted an aluminum or black color or left as is? They are showing some signs of wear and brake dust staining that I am unable to clean off.
Quambomb
2008 BMW 328xi Sedan | Black Sapphire Metallic | Terra leather | Cold weather package | Zenon package
Old 04-20-2014, 08:41 AM
Hd2000fxdl Hd2000fxdl is offline
Mein Auto: 2011 X5
Depends on what type of paint you used on how you can fix it. As with any paint project, 90% of your results will come from how well you did the prep work.
Now as far as paint and what you can do, rememeber Laquer over Laquer, but not over Enamel, Enamel over either.
Thin coats and spray is the best, know times between each coats. for imperfections you can even bondo fill and sand, Clear at the end is your friend and wetsand and polish will also improve the end result.
As a note, I do not di body work at all, I suck at it, but small parts coating where your not dealing with a large smooth panel is easy and results for the DIY'r can be very good.
Don't forget to give a good surface for paint to stick to, etching prime etc..
In the end when you come out with something that just pops and says WOW, it even a better feeling that you did it, and when you can say for how little coin you put out to do it, is icing on the cake..
Harry
Old 05-01-2014, 10:58 AM
mark_m5's Avatar
mark_m5 mark_m5 is offline
Overly Intellectual
Mein Auto: 2002 M5, 2001 996 Turbo
Bondo on brake calipers? Won't it cook?
I'm contemplating painting my calipers because they look rusty. It's cheaper than putting on Brembos...
Mark
Grammar: The difference between "knowing your sh*t" and "knowing you're sh*t."
"A world that is 'idiot proof' is a world that is only fit for idiots." - Racer X / 6'er
Old 05-02-2014, 10:11 AM
Mein Auto: 2011 X5
Now that I think about it, Bondo may not stand up to excess heat over time, there may also be some high temp epoxy's to get the smooth look. I'd talk to a paint shop to see what they would recommend if nobody here has better ideas or real world experience..
Old 05-04-2014, 06:36 PM
i 535 i 535 is offline
Twin Turbo or Die
Mein Auto: 535i Sport
Use paint thinner to get the paint to come off, and for brake caliper paint I recommend G2 caliper paint. I did this to mine, very unprofessionally and easy, and it turned out great.
Old 08-09-2014, 05:01 PM
Parise2713 Parise2713 is offline
Mein Auto: e70 X5
I would try the paint thinner to take it off or even just sanding it down to a nice even base layer with a metal wire brush. I recently painted mine with some caliper painting kit and I think they look great.
Good luck
ID:	457565Click image for larger version
~ Parise2713
Old 08-11-2014, 04:17 AM
Rick D Rick D is offline
Mein Auto: 08 650I Convertible
You will need lacquer thinner to remove the paint, not paint thinner...
