low coolant every 3-4 weeks - Bimmerfest - BMW Forums
Old 06-17-2013, 08:27 AM
vercetti0 vercetti0 is offline
Mein Auto: 2014 BMW 535i xdrive
So I wanted to here from you guys in terms of low coolant message appearing every 3-4 weeks with the car being barely driven. I have a 2011 335i xdrive coupe. On 4/16 the dealer did a pressure test and said there was a lot of air in system and they fixed it. They filled it back with coolant on 5/20 message reappeared. I want to go back to service but manager is saying this normal...its not truely low otherwise it would be overheating...but the reservoir is bone dry...if I go back this would be the 3rd time I go back for the same issue. So the question is it normal?
Old 06-17-2013, 08:32 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
My car has 92k miles. I have added a grand total of 6 ounces of coolant. Your situation is not normal.
Old 06-17-2013, 09:03 AM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Go to another dealership......see if they can find something......If you dont drive your car that much and its in the same spot, are there any wet spots or stains under your car??
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 06-17-2013, 10:55 AM
bear-avhistory's Avatar
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
Its not normal. Had a similar leak & it was a bad hose.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 06-17-2013, 12:42 PM
there are no leaks...I am planning to visit another dealer...it is very unfortunate since I have a very good relationship with this dealership.
Old 06-17-2013, 01:45 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Might be normal for those afflicted with numb nuts, but for most of us, this is real trouble!
Of course your system had air. They gonna diagnose + fix or what? Which dealer was it?
Old 06-17-2013, 02:19 PM
there are no leaks....
Then where is the water going?
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 06-17-2013, 03:19 PM
Could it be....a....head gasket? Sure hope not!
Old 06-17-2013, 04:07 PM
Loosing coolant with "no leaks." Definition of a head gasket, or worse, cracked head.
Old 06-17-2013, 05:05 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
NOT normal, but I had a similar recent experience after routine oil service. They apparently checked the coolant level and put the cap on wrong (cocked) and coolant steadily leaked out. Sometimes it's the simple things...and I hope yours is the same. At lease check for coolant leaking from around the res. cap.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-17-2013, 09:17 PM
i meant to say no visible leaks on the driveway.
Old 06-17-2013, 10:38 PM
Open your oil fill cap & see if it has white sludgy stuff inside it. Coolant in the water.
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 06-21-2013, 08:34 AM
The car has been in service since Tuesday...the dealership stated that they see no leaks and are not sure where the coolant is going...they have pressure tested and everything checks...the SA told me they sentthe data to BMW and are hoping they get some guidance from them.
Old 06-22-2013, 09:42 AM
E92-Lighting's Avatar
Mein Auto: 335i
Originally Posted by jburke4689 View Post
my car has 92k miles. I have added a grand total of 6 ounces of coolant. Your situation is not normal.
+1.
BMW ACCESSORIES and PARTS
Old 06-22-2013, 03:59 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
Based on what evidence? It clearly DOES have a leak, either in the cooling system or in a head gasket. Water does not disappear without a reason.
Or you have leprechauns removing a small amount of coolant every night while you're asleep, but I'm not liking the odds on that one.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 06-23-2013, 08:25 AM
so they finally said they had to replace the exansion tank and a sensor was broken that was reading the coolant...they rplaced both and gave me by car back...I'm hoping this will solve the problem going forward
Old 06-23-2013, 08:34 AM
Did they say why exactly the tank was replaced?
Which sensor?
Old 06-23-2013, 11:30 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
You definitely have a small leak somewhere~
Old 06-23-2013, 12:56 PM
Pilgrim's Avatar
Car guy since 1968
Could easily have been a small leak in the expansion tank.
Old 07-23-2013, 03:52 PM
LycanNyc's Avatar
LycanNyc LycanNyc is offline
BMWCCA '505245
Send a message via AIM to LycanNyc
Mein Auto: F26 X4 M40i LBB
Issue was resolved?
16' F26 X4 M40i LBB | CTSTurbo fmic Custom @AimPerformanceNJ Downpipe | @EnzoRacing PTF/BootMod3| Uniden R3
BM3 N55 vs F80
BM3 N55 vs JB4
CTS-Intercooler Logs/Pics
Check out my YouTube Channel
IG:@Frikiton
Member: BMWCCA #505245
