E36 (1991 - 1999)
Old 06-17-2013, 12:35 PM
Cliff_Idaho Cliff_Idaho is offline
Mein Auto: 323iC, 2002
freeze plug or head gasket or...?
A few days ago my 1998 323i with the 2.5L straight six developed a rather massive leak of coolant from the rear of the engine.
It is actually a steady stream, not drips. There is no coolant in the oil, that I can tell. Oil level is normal. No oil is coming out. As the coolant is flowing out, it drips down between the engine and transmission.
Beyond that, I can't tell where it is coming from. Freeze plug, head gasket, or what else could be the issue in that part of the car? I have already tried taking off the intake manifold, but I don't see fresh coolant up there, and so I gave up on that.
Old 06-18-2013, 09:45 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
I believe there is a freeze plug on the back of the block, so that could be the culprit. See item #13 in this diagram:
1998 BMW 328is
1966 Pontiac GTO
Old 06-18-2013, 09:59 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Is that freeze plug likely to leak, as commonly seen on the OBDII Oil Filter Housing?
Old 06-18-2013, 10:29 PM
ZeGerman's Avatar
Warm Leatherette
In my experience, freeze plugs are not a common source of leaks on engines, including ours, but it can happen. I worked on an engine in the past (Ford 351) that had blown a freeze plug. And since the OP cited a rather dramatic "massive" leak, that sounds like a failed freeze plug to me. Seems like a HG leak would not be "massive". I'm just guessing, though. I'd recommend getting better look with a telescoping mirror.
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 02:42 AM
Burning2nd's Avatar
Under the lift arms
Time to drop zee trans out
15486372<-----
Old 06-23-2013, 02:44 PM
JayMac JayMac is offline
Mein Auto: what ever starts
If need be I have a 6 on a stand and can take some shots and post for you to look at. Can you tell anything about the location? Heater hose leaking or something like that?
