Old 06-17-2013, 09:16 PM
bhatthal bhatthal is offline
Mein Auto: Mercedes ML 63 AMG
Exclamation 2008 BMW 323i Engine Overheating
Hi Guys,
So just bought a BMW 323i a month ago from a dealership. Had all inspection reports done and vehicle was running amazing, had it serviced two weeks ago, they told me everything was great.
Problem is that today a whole bunch of problems showed up:
1) Lock actuators are busted on all four doors, fixed that temporarily by replacing with new fuses
2) Engine light is on, possibly from disconnecting battery to fix lock issues
3) ENGINE IS OVERHEATING - especially around the coolant reservoir, checked all fluids to see if there was any mixing but there is nothing. Then checked for any leaks, nothing as well. No sounds from the engine either....
So what exactly could be wrong on number 3? Any ideas... trying to get into a dealership but can't before July.
Old 06-17-2013, 09:20 PM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
Originally Posted by bhatthal View Post
Hi Guys,
3 is probably the water pump. If you get the pump changed, get the thermostat done as well.
Old 06-18-2013, 08:46 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
Hi bhatthal and welcome to the Fest,
First off having owned a 323i, my money would be on the water pump as well, but I'm not very good at disgnosing issues. Secondly, you have posted in the wrong forum. Your car is an E46(1999-2006) body style. The forum you are looking for is here: http://www.bimmerfest.com/forums/forumdisplay.php?f=98 Lastly, when and if you repost in the correct part of the forum, they are probably going to ask you to provide more information, (i.e creation date, mileage ect.), just a little heads up.
Good luck!
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 06-18-2013, 09:01 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
Good luck!
OP is from canada where there is an E90 323i
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 06-18-2013, 09:21 AM
Fest Wrks
Oh wow my apologies! I just assumed it was previous chassis.
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 06-18-2013, 09:44 AM
No worries Different things in different parts of the world and in terms of the water pump any ideas on cost of repairs?
#323i #engine #overheating
