Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 06-26-2013, 10:50 AM
DslDwg DslDwg is offline
Mein Auto: 2014 Z4 35is
Basically it's the way the Octane number is presented. US and Canada and a couple other countries do it one way while Europe and other parts or the world do it another.
The octane ratings low to high are typically equivalent.
Old 06-30-2013, 04:29 PM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
Originally Posted by DslDwg View Post
... do yourself a favor and use the highest octane fuel available in your new BMW.
Why?
What advantage is there spending more for an octane rating greater than that recommended by the manufacturer?
Octane is not a measure of the gasoline's energy content. It is only a measure that allows a higher compression engine without harmful detonation. Higher compression means a more efficient engine and therefore more energy output per unit of gasoline as long as the computer does not have to retard the spark to prevent detonation. So, if the minimum recommended octane will not result in a retarded spark under worst case conditions, why spend more money on an octane rating greater than that recommended by the manufacturer?
Old 06-30-2013, 04:55 PM
Read my original post I understand the purpose of the octane rating. At the end of the day I don't care what people run in their cars. Are you 100% sure that when you use 89 octane in your car that you aren't detonating? I' m not sure and I'm not willing to take a chance. Your car your choice certainly.
Old 06-30-2013, 06:10 PM
WHITEX's Avatar
WHITEX WHITEX is offline
On our 2nd Alpine X
Mein Auto: 06 X3/2010 MCSC
I did fill (about 5gallons) with 89. If the motor calls for it it's designed to use it. Using a higher octane does nothing. However I will use 91 from now on. My 4 cyc MiniS uses 91.
Detonation is a bad thing. Engine ping is damaging.
GONE>>>Sold. One of the best rides I ever owned. My 1st BMW-2006 X3 3.0 White w/blk. Prem/Nav/Sirius/Servo/Heated seats,steering/Park Dist./Xenon/Privacy.I got the auto. trans. so my wife can drive it.
Our 2nd Bimmer2014 X3 i35 Alpine/Chestnut. Nav,Prem,Tech,Cold Weather, Shades. Got the Automatic cause we had no choice
My 1st Mini-2010 PW, I got the 6 speed so my wife can't drive it. Laurel Edition Convert
Old 07-01-2013, 01:42 AM
Mein Auto: Z3 & X3
I am reasonably sure the recommended rating assures maximum rated engine output under most conditions. Similarly, the minimum rating is the lowest octane the computer & engine can handle and still prevent engine damage from detonation, albeit with a loss of output.
91 is the minimum recommended octane for my Z3, X3, and Lexus RX350. I do not use anything less than 91 but more often than not pump 93 octane simply because 91 is not available. I have followed this practice since I bought a 1988 E30 M3 new. It was the first car I owned requiring the use of "premium" gasoline. Interestingly, my wife inadvertently filled the tank with 89 octane one day. I discovered this almost immediately. I called BMW NA and asked if they thought there would be any harm using the 89 octane gas for a single tank assuming no hard acceleration etc. They were adamant about having the car towed to a dealer to have the tank drained and clearly stated I risked damaging the engine using 89 octane, no matter how few miles or gently it was driven. I actually did drive about 30 miles to a shop and had them drain the tank, with no obvious ill effect for the next 100,000 miles.
I did have a 1985 Nissan 300ZX Turbo. Originally it only required "regular" but after installing an intercooler and increasing the boost from 6 psi to 10-12 psi I used the highest octane I could find. Even then I worried about detonation but never had a noticeable problem.
Old 07-01-2013, 05:51 AM
dudley07726 dudley07726 is offline
Mein Auto: 2012 X3 2.8, 2013 MB E350
I always use 93 Octane for my 2012 X3 2.8. The only time (twice) I had to fill it with Regular 87 Octane was during Hurricane Sandy. When I could get gas, it was only regular that they were selling. I had no choice. I did not notice any ill effects.
Old 07-10-2013, 01:28 AM
ealeisa ealeisa is offline
Mein Auto: 2013 BMW 528I
Since 91 Octane is acceptable, you can derive 91 from 93 and 89 (premium and plus)
Put half the tank 93 and the other half 89 and the average will be 93+89/2= 91...
Saves you money
Old 07-10-2013, 05:19 AM
e1322739 e1322739 is offline
Mein Auto: '13 X1 s28i & '12 X3 35i
93 unleaded all the time ?
I worked at a refinery years ago. They always put their best quality, cleanest burning components into their highest octane premium fuel. Octane boost is not the only benefit of using premium fuel.
Refiners also put their best fuel additive packages in premium fuels. My SA told me he has seen many cars with issues using poor quality gas. He suggested I stick with top tier fuels. (http://www.toptiergas.com/)
Old 07-10-2013, 06:31 AM
WHITEX's Avatar
On our 2nd Alpine X
The fuel door reads Use Premium fuel..."89 Minimum Octane". I'm sticking with 91/92.
Old 07-10-2013, 09:29 PM
LycanNyc's Avatar
LycanNyc LycanNyc is offline
BMWCCA '505245
Send a message via AIM to LycanNyc
Mein Auto: F26 X4 M40i LBB
TopTierGas been using for the past 3yrs never had an issue with engine
PM for Fxx CTS Turbo FMIC & Intake GroupBuy
PM for RaceChip Discount
Current:16' X4 M40i Long Beach Blue LEDs 20's 680M | Custom @AimPerformanceNJ Downpipe | @EnzoRacing PTF/BM3
Past:'14 X3 28i M-Sport AW DHP RaceChip
Bootmod3 0-120mph
Check out my YouTube Channel
IG:@Frikiton
Member: BMWCCA #505245
Old 07-16-2013, 07:37 AM
Ml3456 Ml3456 is offline
Mein Auto: E93 and F25
Worked in refining and fuels technology also. I agree completely. We did a test of fuels years ago. #1with additives was She'll. #2 by only 1% is BP, Then Exxon and Mobil. BP additive was the best cleaner though. The additives (or lack of) in warehouse gas was wakeful and not much of it. Minimum to meet regs.
Old 07-16-2013, 08:12 AM
Mein Auto: Z3 & X3
Please tell me what you mean by "warehouse gas".
I am a big believer in the long term importance of additives. I also buy a lot of gas at a chain of very large discount gas stations in the southeast (RaceTrac). Although this chain sells a lot of gas, the source is certainly not obvious. Never really thought this would be a problem as I assume it has to be one of the major refiners but you comment got me thinking.
Old 07-17-2013, 04:18 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Originally Posted by edbiology View Post
Am I the only one who put 87 in the loaner car?
Lol, who cares, it's not your car anyways :lol:
Old 07-17-2013, 07:55 AM
bimmermann882 bimmermann882 is offline
Mein Auto: BMW
There is a gas station with no ethanol and its 91 I think Is that fine.... I had a X5M at one time....
Old 07-17-2013, 07:58 AM
Mein Auto: BMW
What about no ethanol 91 that I use that is near my house to fill up my old X5M
Old 07-18-2013, 07:29 AM
A lot of the Costco, Sam's etc use cheaper additives and octane boosters sometimes. Don't know about your local chain, but national the majors continue to have the best quality. Lexus and Costco had a settlement due to the amount of fuel injectors Lexus replaced under warranty due to poor Costco fuel. Not worth a buck or two in savings when I bought a performance car.
