E36 (1991 - 1999)
Old 06-18-2013, 02:44 PM
SewageJoe SewageJoe is offline
Mein Auto: 1995 318is
Question Can't seem to find the answer... Tensioner Problem
Hey Guys,
Recently replaced both belts on my 318is (180,000 miles) cause they were squeaking like mad. (dawn can only go so far) After the change the tensioner on the upper belt seems to rock back and forth making a clicking sound when the car is running. Didn't do this before the belt change. Im not sure if i need to replace all the pulleys or if the tensioner is just not keeping the belt tight. New to BMW's so not too sure what Im getting myself into here. Any help is much appreciated.
Old 06-18-2013, 02:57 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
You didn't post what year your E36 is, but there are two types of tensioners, a spring loaded tensioner and a hydraulic tensioner. Both have a pulley on them that's replaceable. If you've got a tensioner pulley that you can actually wobble then the bearing in it is probably gone and it will make quite a squeal.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 06-18-2013, 03:06 PM
Its a 1995 318is,
I believe it is the hydraulic style tensioner. Its not so much a squeaking sound as it was with the old belts. its more of a clicking sound. I think it may be that the hydraulic piston is worn and giving the belt room to pull and tighten on the pulley making a sort of clicking sound. I just wanted to make sure if it was the tensioner or not before i buy the new parts.
Thanks for the help
Old 06-18-2013, 03:36 PM
hornhospital's Avatar
D'oh, You Kids!
Re: Can't seem to find the answer... Tensioner Problem
Joe (Sewage? Really? )I chased a rattle/clicking at the front of my M42 for months. It turned out to be the tensioner. I'll bet you've got the same situation.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 06-18-2013, 03:41 PM
Here is a vid of it.
Old 06-18-2013, 05:04 PM
Screamin's Avatar
Screamin Screamin is offline
Mein Auto: X3, 330ci & 318ti
I'd replace the belt tensioner. It's a fairly inexpensive and simple operation.
Old 06-18-2013, 06:53 PM
D'oh, You Kids!
Hmmm, that's nothing like what mine sounded like. It may still be the tensioner, but mine sounded like a vanos rattle (but there's no vanos on the M42)
Quotes to live by:
Old 06-18-2013, 11:16 PM
yeah just gonna replace the tensioner, thanks guys for the help.
Old 06-18-2013, 11:25 PM
D'oh, You Kids!
Please report back your results. It helps everyone to have record of what was tried and what worked.
Quotes to live by:
Old 06-18-2013, 11:27 PM
ok will do
Old 07-09-2013, 04:12 PM
Thumbs up
Finally got the new part in and the ticking has stopped, seems to have fixed the problem. Ended up being the belt tensioner, the old one pretty much fell apart when i took it out. Thanks again guys for the help.
