E36 (1991 - 1999)
Old 06-19-2013, 08:27 AM
rufus2004 rufus2004 is offline
Mein Auto: 2000 740IL
328 Engine Temperature
My 1997 328ic has 147K and a manual transmission. The radiator, thermostat, fan clutch, and coolant have all been replaced within the last 1k, I also run Water Wetter. I live in the desert and lately the temps have been over 100. The temp gauge usually runs right at the middle, but lately after about 10 miles on the freeway, it creeps up to the 3/4 mark for a couple of minutes and then drops back to 1/2. Due to the outside temp, I shift easy and into 5th quickly and try to cruise at about 2500 rpm, I also have not been running the A/C. Is this a normal situation for this car?, the manual seems to indicate not to be alarmed, but I want to confirm it. Thanks for any input.
Old 06-19-2013, 08:54 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
This is absolutely NOT normal, and needs to be addressed immediately. Even in the desert, the temp gauge should never go above the halfway / 12 o'clock mark. If it does, you have problems. Also, be aware that the temp gauge in these cars unfortunately has a rather large buffer built into it, which means that by the time your temp needle goes above halfway, the actual temp of the coolant is far hotter than what the gauge is indicating, and may actually be so hot that you risk damaging the engine even if the needle hasn't yet gotten to the red.
In all likelihood, you didn't get all the air out of the cooling system when you replaced those parts. Raise the front of the car on jackstands (or park on a hill) and go through the bleeding process a few more times.
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 09:32 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Or just drive it for a few until it gets to normal operating temperature and just bleed until no more bubbles come out. Once you get constant coolant flow every time you loosen the nut, you're good to go. Also check the heat coming out of the vents when you turn on the heater. If it is blowing hot, then warm, then hot, then warm again, you got a bubble.
And so long as the needle doesn't STAY in the red, you're fine. Your needle should be bouncing back and forth when there is an air pocket.
Also, I'd recommend feeling the hoses as well. If they are ROCK hard, you got a big air pocket in there.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 06-19-2013, 09:38 AM
Burning2nd's Avatar
Under the lift arms
T stat or water pump
No point in trying to bleed it any further at this point the air has already moved to the tank ... In the morning the car will be cool check and see if the antifreeze is low if it is top off and that was your problem if not and it is intact at its normal level . Then stat and pump
15486372<-----
Old 06-20-2013, 02:42 AM
Burning2nd's Avatar
Under the lift arms
It probably wasn't bleed completely
but now 10 miles later, It certainly is
15486372<-----
Old 06-20-2013, 03:35 AM
hnaz's Avatar
BMW CCA Member
I'm reading an echo...
My Previous Work:
Old 06-20-2013, 06:09 AM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Cool Cool Cool. echo echo echo.
Hey, stop coping me. Hey, stop coping me. Hey, stop coping me. I mean it. I mean it. I mean it.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 06-20-2013, 09:09 AM
ZeGerman's Avatar
Warm Leatherette
In all likelihood, you didn't get all the air out of the cooling system....
The cooling systems in our E36s do not self-bleed, so even if trapped air has risen to the tank, it will still need to be released, which is why I initially suggested bleeding the system again.
1998 BMW 328is
1966 Pontiac GTO
Old 06-20-2013, 09:45 AM
Burning2nd's Avatar
Under the lift arms
Yeah what I was saying , simple
After the car cooled down it sucked in the fluid , and the tank would have been low the next morning ...
But you all already know that
15486372<-----
