Old 06-19-2013, 01:48 PM
pastman pastman is offline
Mein Auto: 2007 328xi
Unhappy Power steering fluid is low
Hello Members:
Mylocal Valvoline oil change just informed me that the power steering fluid level is at minimum (2007 328xi coupe - 98K). They explained that the reservoir is attached by a crimping device rather than a regular clamp, I have a slow leak.
I've read (on the net) that I should replace all of the fluid and the reservoir receptable and filter. Please give me your thoughts (and experience) on the subject
Thanks,
Al
Old 06-19-2013, 01:55 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I'm not sure on the 328s, but some of the newer reservoirs have a built-in filter that cannot be serviced. If there is a leak, and the host/clamp is replaced, a drain/fill is warranted.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-19-2013, 02:02 PM
Hello there "Kurgan":
Thanks for the quick reply and helpful info. PS: Wasn't the Kurgan Duncan McLeod's nemesis in 'Highlander'?
Thanks again for the help
Old 06-19-2013, 02:40 PM
thekurgan's Avatar
Bad Lieutenant
Kurgan was Connor's nemesis.
Duncan didn't appear until the Canadian-based TV series; he was Connor's cousin.
Ilse
Bruna
BMWCCA #453648
Old 06-20-2013, 07:47 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
minimum at 98k is most likely evaporation though the small vent in the reservior cap. Look at it and it will be dirty. I would clean it up and top it off. If you are going to flush and change the fluid then get a new reservior and clamps.
Old 06-20-2013, 09:18 AM
Hello jburke:
I appreciate the feedback, thanks. Do I have to use BMW specific fluid?
Alan
Old 06-20-2013, 09:19 AM
thekurgan's Avatar
Bad Lieutenant
Hello jburke:
Alan
I "believe" it's Pentosin CH-11S, but someone else may know more.
Ilse
Bruna
BMWCCA #453648
Old 06-20-2013, 12:56 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Kurgan is correct per usual. That one is for our hydraulic, I don't know why anyone would consider non OEM when it's maybe $20 for the container. The newer electric systems need to use a different fluid.
Old 06-20-2013, 01:43 PM
thekurgan's Avatar
Bad Lieutenant
Yes my bad, I kept thinking n54/n55:
http://www.ecstuning.com/BMW-E90-328.../Fluid/ES1802/
Ilse
Bruna
BMWCCA #453648
Old 06-20-2013, 02:20 PM
The type you need is on the cap of the reservior. You can get it at any NAPA. But it does need to be what is on the cap. Petosin is the most common.
Old 06-20-2013, 03:15 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
Keep it filled until fixed. You do NOT want it running dry!
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 06-20-2013, 04:03 PM
wooohooo
Hm! You know what, I recently watched a YT video by "AskTheCarExperts" that was working on a BMW X3 with N52 engine, and the cap and container were clearly marked with CHF 11S. If your correction is correct, well I guess I really can't assume anything at all... I thought if both the N52 X3 and N54 335i used CHF... OP, check the cap!
Old 06-20-2013, 04:25 PM
thekurgan's Avatar
Bad Lieutenant
I was confused too, CHF 11S is really common. On both the M3s, I did the turkey baster replacement with it and it was on the cap. If someone can check their cap, that would be helpful. I'll check realoem and see if there is any information.
Edit:
penske shows the fluid listed here for the E90 328xi: http://www.penskeparts.com/DiagramsM...8&rnd=03192010
CHF 11S is listed
Click the steering section:
Name:	Screen Shot 2013-06-20 at 4.26.59 PM.png
Ilse
Bruna
BMWCCA #453648
Old 06-20-2013, 04:38 PM
wooohooo
Nice due diligence^!
