E36 (1991 - 1999)
Old 06-19-2013, 03:49 PM
newburgfdz71 newburgfdz71 is offline
Mein Auto: 1998 328i
another misfire problem
ok so the last week i have been reading misfire thread after misfire thread on several forums, and none really match my problem. i have a 98 328i 5speed car and it only seams to act up when under load or if i jump on it. when it misfires its almost like someone has shut the fuel off then turned it back on and sometimes the car will completely shut off and the only way to get it to really start is to start it in gear. i have replaced the fuel pump, fuel filter, spark plugs, coils, and cleaned the maf all within the last 6 months
Old 06-20-2013, 08:17 AM
i forgot to mention that the cyclone valve was replaced and the icv was cleaned about a month ago when i was doing other maintence on the car
Old 06-20-2013, 08:18 AM
and also no vac leaks
Old 06-20-2013, 09:30 AM
LordlierPie7781 LordlierPie7781 is offline
Mein Auto: 93 Dinan S3, 325is base
Im new to wrenching on these cars, but it looks like you cleaned or replaced everything but the fuel rail, is that a part that could cause this issue? or maybe the injectors are not in good condition? just two thoughts on it.
Old 06-20-2013, 09:36 AM
Leusent Leusent is offline
Mein Auto: 328is
Perhaps you've got some gunk built up in the fuel rail?
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 06-21-2013, 06:35 PM
ok so tonight i waas messing around with my car and noticed that my vanos is starting to rattle could this cause my problems
Old 06-21-2013, 07:16 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Have you checked the throttle position sensor? It's what tells the DME where the throttle butterfly is positioned. If the TPS is going open momentarily it will be like you've taken your foot off the throttle.....
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 06-21-2013, 08:47 PM
tps is only about 8 months old
Old 06-22-2013, 06:56 AM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
Is it an OEM sensor or after market?
Old 06-22-2013, 09:14 AM
dc_wright's Avatar
Is the CEL illuminated and/or have you had the fault codes read?
Old 06-22-2013, 10:54 AM
tps is an aftermarket sensor and i just got my reader back off my bother so i still have to check. i will repost as soon as i pull my codes
Old 06-22-2013, 10:56 AM
as far as the cel being illuminated i dont know because the po had removed the bulb and bulb holder so i need to order some up
Old 06-22-2013, 11:45 AM
dc_wright's Avatar
Your car is OBD2 so you can go to any of the big box parts stores (Advance, Autozone, etc.) and they'll connect a scanner and read the codes for you for free. I would do that before I tried anything else. Without knowing what faults the DME is seeing you're just wasting money throwing parts at this problem.
