E30 (1982 - 1993)
Old 06-19-2013, 07:21 PM
scharf1 scharf1 is offline
Mein Auto: 84 318i
Update time
So from previous posts i have had issues with my 1984 318i, horrible miss fire from idle to about 2500 rpms. after that it will rev and drive like a rocket ship. now then on the what i have done to the car in the last month:
all new vac lines
tested tps
tested mas
new intake manifold gaskets (stud was stripped out, also one gasket was put on backwards which blocked half of the intake port, all fixed up)
new cap
new rotor
new plugs
new wires
No back to the bad, none of which fixed my issue. it is a little more peppy on the road once i get above 2500 rpm (mostly due to the blocked port and stripped out stud). however my issue still remains. the next step is to start replacing fuel components. it is running VERY rich when running between idle and 2500 rpm.
but here the weird part that makes me think its not fuel related. it runs PERFECT when ice cold. once the car starts to get to operating temperature that is when it starts to run bad. so if anyone wants to throw out suggestions feel free.
Old 06-19-2013, 07:38 PM
downhiller's Avatar
livin large
sounds more like ecu now......how bout the fpr? cant remember if you changed that or not
Old 06-19-2013, 08:07 PM
Mein Auto: 84 318i
That's what I am going to replace next.
Old 06-20-2013, 07:14 PM
downhiller's Avatar
livin large
ecu or fpr?
Old 06-23-2013, 03:36 PM
Mein Auto: 84 318i
Fpr
