Oil Sensor accuracy???? - Bimmerfest - BMW Forums
Old 06-22-2013, 06:36 AM
ctlyankee ctlyankee is offline
Mein Auto: Acura TL
Two months ago, while driving, a warning flashed that I should add a quart of oil ASAP. I had the oil changed only 10 weeks prior, so I doubted that it would need oil already. I pulled over and shut the engine off then restarted. At that point I ran the check oil level and it showed it was at the max. Yesterday the warning came on again, so I pulled over to check the level after I restarted it said the oil level was OK but only showed about 1/4 over the min. So I stopped at the dealership on my way home and they put a quart of oil in but the level still shows about 1/4 over min. After driving today I checked the level again and the level has not changed. I really wish it had the "old fashion" dipstick to check oil levels. I read a few other posts on this problem but I could not find a definitive outcome. How many others experienced this problem? BTW: The representative at the dealership stated it was not unusual for BMWs to need oil added between changes. - I find that somewhat disconcerting.
Old 06-22-2013, 07:58 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
Sounds like you have a intermittent oil level sensor problem rather than a accuracy problem or an actual oil leak problem. If this problem occurs again, I would ask your dealer to check the actual amount of oil you have in the engine by draining and measuring the volume.
