Doing my homework before having new tires installed - Bimmerfest - BMW Forums
Old 06-20-2013, 09:44 AM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
The unfortunate appearance of a screw impaling itself in my right front tire has hastened replacing the tires on my E93.
I’ve done my homework and purchased the tires, but I have a couple of questions regarding balancing, and yes I’ve done my “search” but there is too much contradictory information on the intarwebs.
1) I’ve done the research regarding Hunter Road Force Balancing and my tire shop uses this technology, but if I’m planning on rotating my tires, should they be road balanced every time they are rotated? And yes – I know the BMW company line says don’t rotate and yes, my car is a square (not staggered) setup.
http://www.hunter.com/videos/index2.cfm?v=17&cat=3
2) With regard to wheel weights:
a) I presume they are going to ‘scrape’ the current wheel weights off before they start the balancing, or do they first see how the current weights behave? How do they detach adhesive wheel weights anyway?
b) I just finished detailing my wheels two weeks ago which included a nice healthy coat of Rejex. Is this going to make it difficult to get new wheel weights (presuming they need to add some) to adhere?
TIA-
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 06-20-2013, 10:24 AM
thekurgan's Avatar
thekurgan thekurgan is online now
Bad Lieutenant
Mein Auto: S62B50 Powered
TIA-
#1 - I only re-balance yearly if I have a vibration, if square, absolutely rotate them.
#2 - I always have to ask, but honestly, they don't do the job that I would with 3M adhesive remover when I get home from the tire shop. 2b) possibly, you may want to mention that they use some alcohol before applying the weights; I've had weights fling off and I am betting it's from opti-coating them or perhaps the tech didn't clean the area first.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-20-2013, 10:37 AM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Have a full tank of gas, when you go in for the tire swap/balancing. Check the latest Roundel issue. I believe Mike Miller went into a great detail about the proper way of using the Hunter Road Force machine and some of the common mistakes made by techs that use the equipment.
Out of curiosity, what tires did you end up getting?
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 06-20-2013, 10:50 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
Regarding the weights, yeah, I've had techs just peel the old ones off and leave the adhesive... Maybe that's better though because I could get it off gently rather than scraping it off with a screwdriver like they might have.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights - blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 06-20-2013, 12:01 PM
Nordic_Kat's Avatar
Thanks for the heads-up regarding the article in Roundel. Will need to make that my weekend reading assignment.
I decided to stick with the existing Conti ProContact RFTs. They seem to be a good fit with the car and my style of driving. I must say though, it was one of the hardest decisions, but ultimately not wanting to sacrifice what little trunk space I have plus the additional weight on an already heavy car factored heavily into the final decision to stay with RFTs. Then, it was just a matter of settling on which brand. I almost had myself sold on the Michelin MXM4 ZPs but the idea of likely only getting 15K out of them was a deal breaker.
Old 06-20-2013, 05:35 PM
Nordic_Kat's Avatar
Thanks for the tips with regard to the 3M adhesive remover and alerting the installer to swab the area before applying the weight.
What I find interesting about the Hunter system, is that when the tires are new, they put the two "best" or most closely matched tires on the front of the car. But, if one is following a traditional rotation pattern with non-directional tires, that means at the first rotation, the optimum setup as determined by the road force balancing systems is now completely tossed out the window. This is why I ask if re-balancing the tires is an ongoing process during the life of the tires. This used to be much simpler.
Old 06-20-2013, 06:56 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
[QUOTE=Nordic_Kat;7662975]The unfortunate appearance of a screw impaling itself in my right front tire has hastened replacing the tires on my E93.
I've done my homework and purchased the tires, but I have a couple of questions regarding balancing, and yes I've done my "search" but there is too much contradictory information on the intarwebs.
1) I've done the research regarding Hunter Road Force Balancing and my tire shop uses this technology, but if I'm planning on rotating my tires, should they be road balanced every time they are rotated? And yes – I know the BMW company line says don't rotate and yes, my car is a square (not staggered) setup.
a) I presume they are going to 'scrape' the current wheel weights off before they start the balancing, or do they first see how the current weights behave? How do they detach adhesive wheel weights anyway?
TIA-[/QUOTE
The current wheel weights have a "gummy" adhesive and will (should) be removed with a specialized tool: a plastic "putty knife" that won't scratch the base of your wheels. Solvent will remove the goo remaining from the weights.
Since there's virtually no chance that the current weights are properly placed, they'll be stripped off.
Be sure to ask for a "print out" from the GSP machine so we'll know the "radial force" after final "balancing." Ask for TWO readings from the machine:
1. "total indicated reading" (TIR) per tire/wheel
2. 1st radial harmonic per tire/wheel assembly
Tires with the highest 1st radial harmonic should go on the rear, but this doesn't necessarily mean that they need to be rebalanced at rotation IMO.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-20-2013, 07:14 PM
Nordic_Kat's Avatar
So how does it work after the first 7000 miles when it's time to rotate:
Is Rearward Cross or X-pattern the preferred way to go? And how does this impact the 1,2,3,4 positioning as determined by the initial Road force balancing? Or, conversely, does the initial road force balancing impact the rotational pattern? Now do you see my confusion?
One more question: I'm an analytical chemist. I routinely weigh things to 4 decimal places. What is the closest unit of measure used to balance tire/wheel assemblies? ie 1 oz, 0.1oz?
Old 06-20-2013, 07:39 PM
pointandgo's Avatar
Your rotation pattern will be dictated by the tire tread design that you get, for example "modern" tread designs are "asymmetrical" intended to have one sidewall facing outwards. This limits your rotation options (Tire Rack's web site should show rotation options by tire tread type). I would stay away from "directional" tread designs. They're out of favor and tend to generate road noise as they wear.
You can consider a non-directional, non-asymmetrical tread design that would increase your rotation options, but I don't have a tire rec. in mind at the moment. I'm not opposed to 'X' type rotations (same wheel dimensions on all four), but opinions will vary on this.
As for the 1,2,3,4 positioning, I would keep the best tires on the the front, the best tire on the driver's side (LF), and "worst" tires on the passenger side overall.
If the "road force" results show very low "1st radial harmonics" for all tires (and the dealer can "match mount" specific tires to specific wheels to minimize RFV levels), I wouldn't worry about future rotation.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 06-20-2013, 08:16 PM
floydarogers's Avatar
Pedant and Curmudgeon
As for the 1,2,3,4 positioning, I would keep the best tires on the the front, the best tire on the driver's side (LF), and "worst" tires on the passenger side overall. ....
I'm curious about your reasoning on this. Tirerack recommends that new tires (the best) be placed on the rear, due to problems with severe over-steer caused by if the rear aqua-planes.
Old 06-20-2013, 08:21 PM
pointandgo's Avatar
That would apply when only two new tires are being fitted on a car, and has to do with the tread depth of the new tires being able to displace water -- resist hydroplaing -- better than more worn tires.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 06-20-2013, 09:27 PM
Perhaps you should be more specific with what you mean by "best" tires. To me, it means deeper tread, worn fairly evenly. Of course, BMWs tend to wear the insides more than the center, and the fronts wear the outsides a bit more, too.
Old 06-21-2013, 04:53 AM
Nordic_Kat's Avatar
The link I posted in my original post contains a video made by Hunter how the road force balancing process works. Essentially, the tires are matched with regard to weight, lateral forces and the two tires that best match are put on the front of the car, which is the context I think PNG was going for based on my question to him about the "1,2,3,4" positioning.
Old 06-21-2013, 06:07 AM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
How would which sidewall is facing outwards change when rotating tires? Only way that'd happen would be to dismount the tires from the rims.
Perhaps you're thinking of directional tires designed to rotate only in one direction? In those cases you do need to keep the tire on the same side of the car. No cross rotation to the other side.
Old 06-21-2013, 07:06 AM
thekurgan's Avatar
Bad Lieutenant
If you're placing with the same brand/size, and you got great service life from them (aside from the early termination of one), I would keep doing what you did with the original tires. I think using the best tires in the front, keeps the vibrations down and the rear wheel drive allows the non-best tires to break in without noticing the vibration. That's just my guess.
It's actually still simple, I think this board is grossly overcomplicating the matter.
Ilse
Bruna
BMWCCA #453648
Old 06-21-2013, 07:11 AM
This is why I don't rotate anything but my snow tires (a square setup) - performance is measured a little differently on them, and a little vibration aren't so important ...
Old 06-21-2013, 07:28 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Kat, you didn't ask this but it's worthwhile to have your tire shop look at the wear pattern on the 4 tires coming off and see if there is reason to have a 4 wheel alignment done along with the new tire mounting.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 06-21-2013, 08:08 AM
Nordic_Kat's Avatar
Interesting that you mention this. I just got off the phone with the tire shop setting up the install appointment. They asked if I wanted an alignment done. As I just had one done last fall, I declined. They said they would at no charge run a check printout on it and see how it's doing.
Is this hype or real?
Old 06-21-2013, 08:49 AM
laser's Avatar
If no tire wear indicates and you just had one done last fall this sounds like the best path.
Hopefully Houston gumbo clay subsidence and the resulting potholes have "subsided" since my days there in the 80's.
Laser
Old 06-21-2013, 08:53 AM
Nordic_Kat's Avatar
Still no lack of potholes. I just do inordinate planning to stay away from the streets that look like warzones. Of course, occasionally there is the surprise sink hole that opens up overnight.
Old 06-24-2013, 06:52 AM
tmdals0213 tmdals0213 is offline
Mein Auto: E93 335is 2013
wow, this post really enlightened me on the science of tire technology and made me more aware of how important tire care and tires are for safety. Great post OP! and thanks everyone for the awesome replies.
