The X5 SAV Forum
Old 06-20-2013, 01:52 PM
maintainer747 maintainer747 is offline
Mein Auto: 2001 BMW X5 4.4i
200k X5 Maintenence
I have a 2001 X5 4.4i with 170k, still runs very smooth and fast but I am hearing that I need to start looking to change some parts out beginning with the lifetime timing chain. the water pump and cooling fan were changed a few months back but I was told that the timing chain was a lifetime part. what suggestions do you have for me and what is most important in order of necessary maintenance and what is advisable but not as critical?
Old 07-05-2013, 08:04 AM
Maintenance for high mileage X5
Still looking for some suggestions on what I should focus on as suggested maintenance for X5 4.4i with 170k. It stills run strong and fast, I just want to make sure it stays that way without having to put it in the shop. What should I definitely start to replace now to avoid failure and what is not as important based on your experience?
Old 07-05-2013, 05:04 PM
x5alpine x5alpine is offline
Mein Auto: jeep wrangler
do the cooling system and timing chain guides first as well as all the other tensioners and seals in and around then engine.
Old 07-05-2013, 10:36 PM
re: 200K maintenance
Thank you for your suggestions....I just purchased the timing chain, the guide, and the upper and lower tensioners. I also purchased the valve cover gaskets and the crankshaft seal. I plan on taking it to my mechanic next Saturday to have these things done...I also was wondering should I change the pre-cat O2 sensors now? and how about the purge valve (otherwise known as a PCV valve on most cars)?
Old 07-06-2013, 06:14 PM
yes, anything while your in there. especially the PCV even if you don't really live in a cold climate
200k maintenance, upkeep
